Home » Modeling » EMF » TRANSACTION: using transactional editing domain from wizard
TRANSACTION: using transactional editing domain from wizard [message #417412] |
Sat, 08 March 2008 09:07  |
My wizard action includes:
final TransactionEditingDomain domain = ...
try {
domain.runExclusive(new Runnable() {
public void run() {
Display.getDefault().syncExec(domain.createPrivilegedRunnabl e(
new Runnable() {
public void run() {
//do stuff
}catch (InterruptedException e) {
When I run it runExclusive notices that the wizard thread is the current
thread instead of the domain's thread and hangs starting a new txn. This
behavior seems to defeat the purpose of handing the stuff to the domain's
thread for execution.
As an aside, the help topic "sharing transactions with other threads",
refers incorrectly to Domain.syncExec() instead of
Domain.getDefault().syncExec().
Thanks!
Larry
Re: TRANSACTION: using transactional editing domain from wizard [message #417422 is a reply to message #417419] |
Mon, 10 March 2008 09:30   |
Hi, Larry, Ed,
I can only add a bit of elaboration (in-line) on Ed's responses.
HTH,
Christian
Ed Merks wrote:
> Larry,
> I should wait for Christian to answer but looking at the code, it seems
> very wrong...
>> try {
>> public void run() {
> If the display thread is busy this will block and be delayed. If the
> display thread itself is locked, this will deadlock. It seems
> dangerous. The display knows nothing of transactions, so don't expect
> the display's exec mechanisms to do anything smart with regard to
> transactions...
There wouldn't be much point in starting a transaction on a thread when all
that it intends to do is call Display.syncExec() to do a transaction on the
UI thread.
Try simply this:
Display.getDefault().syncExec(new Runnable() {
private boolean inTransaction;
public void run() {
if (inTransaction) {
// do stuff
} else {
try {
inTransaction = true;
domain.runExclusive(this);
} catch (...) {
} finally {
inTransaction = false;
Also, the wizard code is probably running on a ModalContext thread, and that
can be very tricky because the modal context has special knowledge of the
UI thread and actually takes over some of its responsibilities temporarily.
For example, it handles window-system events but ignores async runnables.
>> new Runnable() {
>> public void run() {
>> //do stuff
> I suspect this is because the transaction immediately tries to run
> something on the display thread in a way that blocks the transaction
> until it's done. What goal is this trying to accomplish?
>> This
> Yes. But asking a transaction to do something that blocks until the GUI
> thread does something seems self defeating.
Well, sometimes code that needs to synchronize with the UI is invoked in a
transactional context against its will, which is why the privileged
runnable mechanism is provided. However, it doesn't seem necessary in this
case, where the code that is synchronizing with the UI is also creating the
transaction.
I expect that the documentation refers to Display.syncExec() merely as a
qualified reference to the syncExec() API, not intending it as an example
of an actual invocation. Sometimes the default display is not the
appropriate choice, as in a multiple-display environment. Usually, it is
safest to get the display context from some appropriate widget, such as a
workbench-window shell.
> Maybe the transaction should be doing whatever non-GUI work it needs to
> do and then hand off further processing to the GUI thread via an
> asyncExec which then can acquire a lock of its own. Then again, maybe I
> don't know what I'm talking about. Christian will correct me I'm sure.
Well, sometimes synchronous communication between threads is simply
required. That's quite normal. OTOH, sometimes an asynchronous design can
be employed, instead.
>> Thanks!
>> Larry
Re: TRANSACTION: using transactional editing domain from wizard [message #417424 is a reply to message #417423] |
Mon, 10 March 2008 09:37   |
--------------010504090301070507020104
Larry,
That much I understood, but you're immediately tossing control back to
the GUI thread. I don't understand that part. Likely you started on
the GUI thread in the first place. Hopefully Christian's information is
more clear than mine...
> "What goal is this trying to accomplish?"
> I'm trying to modify objects in the editing domain. The
> TransactionChangeRecorder objects to the changes because they are being made
> in the wizard's thread instead of the editing domain's thread. This code
> (copying the doc) is attempting to hand the change actions to the other
> thread.
> And of course, I meant Display.getDefault().synchExec()
> "Ed Merks" <merks@ca.ibm.com> wrote in message
> news:fr38up$fmv$1@build.eclipse.org...
>> Larry,
>> very wrong...
>>> try {
>>> public void run() {
>> display thread itself is locked, this will deadlock. It seems dangerous.
>> The display knows nothing of transactions, so don't expect the display's
>> exec mechanisms to do anything smart with regard to transactions...
>>> new Runnable() {
>>> public void run() {
>>> //do stuff
>> something on the display thread in a way that blocks the transaction until
>>> This behavior seems to defeat the purpose of handing the stuff to the
>>> domain's thread for execution.
>> Maybe the transaction should be doing whatever non-GUI work it needs to do
>> and then hand off further processing to the GUI thread via an asyncExec
>> which then can acquire a lock of its own. Then again, maybe I don't know
>>> Thanks!
>>> Larry
<html>
<head>
</head>
Larry,<br>
<br>
is more clear than mine...<br>
<br>
<br>
<blockquote cite="mid:fr3dc2$bj0$1@build.eclipse.org" type="cite">
<pre wrap="">"What goal is this trying to accomplish?"
thread.
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fr38up$fmv$1@build.eclipse.org">news:fr38up$fmv$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Larry,
very wrong...
</pre>
<pre wrap="">My wizard action includes:
try {
public void run() {
</pre>
</blockquote>
<pre wrap="">If the display thread is busy this will block and be delayed. If the
</pre>
<pre wrap=""> new Runnable() {
public void run() {
//do stuff
</pre>
</blockquote>
<pre wrap="">I suspect this is because the transaction immediately tries to run
</pre>
<pre wrap=""> This behavior seems to defeat the purpose of handing the stuff to the
</pre>
</blockquote>
<pre wrap="">Yes. But asking a transaction to do something that blocks until the GUI
</pre>
<pre wrap="">
</pre>
</blockquote>
<pre wrap="">Maybe the transaction should be doing whatever non-GUI work it needs to do
</pre>
<pre wrap="">Thanks!
Larry
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------010504090301070507020104--
Re: TRANSACTION: using transactional editing domain from wizard [message #417425 is a reply to message #417422] |
Mon, 10 March 2008 10:03   |
Thanks Christian
When I run with this variation,
public void run() {
// do stuff
} else {
try {
} catch (...) {
} finally {
TransactionChangeRecorder.assertWrite() stilll objects that the domain
thread doesn't match the current thread.
Larry
"Christian W. Damus" <cdamus@ca.ibm.com> wrote in message
news:fr3d59$998$1@build.eclipse.org...
> Hi, Larry, Ed,
> HTH,
> Christian
> Ed Merks wrote:
>> Larry,
>> very wrong...
>>> try {
>>> public void run() {
>> transactions...
> all
> the
> UI thread.
> Try simply this:
> public void run() {
> // do stuff
> } else {
> try {
> } catch (...) {
> } finally {
> that
> temporarily.
>>> new Runnable() {
>>> public void run() {
>>> //do stuff
>>> This
>>> domain's
> this
> the
> transaction.
> can
>>> Thanks!
>>> Larry
Re: TRANSACTION: using transactional editing domain from wizard [message #417426 is a reply to message #417425] |
Mon, 10 March 2008 10:38   |
--------------060802030401040101000202
Larry,
The Javadoc is pretty clear that runExclusive is for doing a read-only thing
* Runs an operation that requires exclusive access to my resource set,
* for reading. The specified runnable is executed in a read-only
* transaction
If you're trying to make changes to the model, you'd need to do that as
a command so that the result is undoable...
> Thanks Christian
> public void run() {
> // do stuff
> } else {
> try {
> } catch (...) {
> } finally {
> Larry
>> Hi, Larry, Ed,
>> HTH,
>> Christian
>> Ed Merks wrote:
>>> Larry,
>>> very wrong...
>>>> try {
>>>> public void run() {
>>> transactions...
>> all
>> the
>> UI thread.
>> Try simply this:
>> public void run() {
>> // do stuff
>> } else {
>> try {
>> } catch (...) {
>> } finally {
>> that
>> temporarily.
>>>> new Runnable() {
>>>> public void run() {
>>>> //do stuff
>>>> This
>>>> domain's
>> this
>> the
>> transaction.
>> can
>>>> Thanks!
>>>> Larry
<html>
<head>
</head>
Larry,<br>
<br>
thing<br>
<br>
set,<br>
* for reading. The specified runnable is executed in a read-only<br>
* transaction<br>
<br>
a command so that the result is undoable...<br>
<br>
<br>
<blockquote cite="mid:fr3f48$s8c$1@build.eclipse.org" type="cite">
<pre wrap="">Thanks Christian
public void run() {
// do stuff
} else {
try {
} catch (...) {
} finally {
Larry
"Christian W. Damus" <a class="moz-txt-link-rfc2396E" href="mailto:cdamus@ca.ibm.com"><cdamus@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fr3d59$998$1@build.eclipse.org">news:fr3d59$998$1@build.eclipse.org</a>...
</pre>
<pre wrap="">Hi, Larry, Ed,
HTH,
Christian
Ed Merks wrote:
</pre>
<pre wrap="">Larry,
very wrong...
</pre>
try {
public void run() {
</pre>
</blockquote>
transactions...
</pre>
</blockquote>
<pre wrap="">There wouldn't be much point in starting a transaction on a thread when
all
the
UI thread.
Try simply this:
public void run() {
// do stuff
} else {
try {
} catch (...) {
} finally {
that
temporarily.
</pre>
public void run() {
//do stuff
</pre>
</blockquote>
</pre>
<pre wrap=""> This
domain's
</pre>
</blockquote>
</pre>
</blockquote>
<pre wrap="">Well, sometimes code that needs to synchronize with the UI is invoked in a
this
the
transaction.
</pre>
<pre wrap="">As an aside, the help topic "sharing transactions with other threads",
</pre>
</blockquote>
</blockquote>
<pre wrap="">I expect that the documentation refers to Display.syncExec() merely as a
</pre>
</pre>
</blockquote>
<pre wrap="">Well, sometimes synchronous communication between threads is simply
can
</pre>
Larry
</pre>
</blockquote>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------060802030401040101000202--
Re: TRANSACTION: using transactional editing domain from wizard [message #417429 is a reply to message #417425] |
Mon, 10 March 2008 11:51   |
Hi, Larry,
Sorry, I seem to have failed to notice that you are attempting to modify the
contents of your resource set. Not a good start to my week :-(
the runExclusive() API gives the current thread only read-only access to the
resource set. In order to modify, you need read/write access, which is
provided by execution of a command.
Try this:
public void run() {
try {
domain.getCommandStack().execute(
new RecordingCommand(domain, "some label") {
... doExecute(...) { /* do stuff */ }
} catch (...) {
HTH,
Christian
> Thanks Christian
> public void run() {
> // do stuff
> } else {
> try {
> } catch (...) {
> } finally {
> Larry
>> Hi, Larry, Ed,
>> HTH,
>> Christian
>> Ed Merks wrote:
>>> Larry,
>>> very wrong...
>>>> try {
>>>> public void run() {
>>> transactions...
>> all
>> the
>> UI thread.
>> Try simply this:
>> public void run() {
>> // do stuff
>> } else {
>> try {
>> } catch (...) {
>> } finally {
>> that
>> temporarily.
>>>> new Runnable() {
>>>> public void run() {
>>>> //do stuff
>>>> current thread instead of the domain's thread and hangs starting a new
>>>> txn.
>>>> This
>>>> domain's
>> a transactional context against its will, which is why the privileged
>> this
>> the
>> transaction.
>> can
>>>> Thanks!
>>>> Larry
Re: TRANSACTION: using transactional editing domain from wizard [message #417438 is a reply to message #417429] |
Mon, 10 March 2008 14:45  |
That was it...Thanks!
news:fr3lel$gka$1@build.eclipse.org...
> Hi, Larry,
> the
> the
> Try this:
> public void run() {
> try {
> } catch (...) {
> HTH,
> Christian
>> Thanks Christian
>> public void run() {
>> // do stuff
>> } else {
>> try {
>> } catch (...) {
>> } finally {
>> Larry
>>> Hi, Larry, Ed,
>>> HTH,
>>> Christian
>>> Ed Merks wrote:
>>>> Larry,
>>>> very wrong...
>>>>> try {
>>>>> public void run() {
>>>> transactions...
>>> all
>>> the
>>> UI thread.
>>> Try simply this:
>>> public void run() {
>>> // do stuff
>>> } else {
>>> try {
>>> } catch (...) {
>>> } finally {
>>> that
>>> the
>>> temporarily.
>>> runnables.
>>>>> new Runnable() {
>>>>> public void run() {
>>>>> //do stuff
>>>>> txn.
>>>>> This
>>>>> domain's
>>>> GUI
>>> this
>>> the
>>> transaction.
>>> example
>>> is
>>> a
>>> can
>>>>> Thanks!
>>>>> Larry
Current Time: Sun Oct 19 10:11:05 EDT 2025
Powered by FUDForum. Page generated in 0.04917 seconds
