Home » Modeling » EMF » Generated editor as standalone RCP supported in EMF 2.1.1?
Re: Generated editor as standalone RCP supported in EMF 2.1.1? [message #396753 is a reply to message #396744] |
Thu, 10 November 2005 08:46   |
Adelino,
Yes, you should be able to deploy the generated editor for RCP.
I've never seen this out of memory error. There is a JVM option to
increase the amount of memory, but I don't remember what it is. If
export is failing even when there is enough memory, that would be a
problem to open a platform bugzilla about (or maybe export is provided
by the PDE). Did things complete enough that you could proceed to step
2? Did your application function properly when testing it without
exporting it?
Adelino Rodrigues wrote:
>Hi,
>After setting the Editor.Rich Client Platform to true, and following steps
>from the "EMF goes RCP" article, the editor runs as an RCP application. This
>is absolutely brilliant!
>Is deployment of the generated editor as standalone RCP supported?
>Following steps described in "RCP tutorial Part 1", I face following issues
>when exporting the .editor project :
>1) A java.lang.Memory error is thrown towards the end of the export process.
>2) The exported editor starts but when opening a model nothing happens
>Regards, Adelino.
>Referenced articles:
> http://www.eclipse.org/articles/Article-EMF-goes-RCP/rcp.htm l
> http://www.eclipse.org/articles/Article-RCP-1/tutorial1.html
Re: Generated editor as standalone RCP supported in EMF 2.1.1? [message #396760 is a reply to message #396753] |
Thu, 10 November 2005 10:49   |
Originally posted by: adelino.rodrigues.emea.eu.int
Running the editor without exporting works without any error.
Although there was an error during the export, I could start the exported
app.
Regards, Adelino.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:dkvj01$qjt$1@news.eclipse.org...
> Adelino,
> exporting it?
> >Hi,
steps
This
issues
process.
> >Regards, Adelino.
Re: Generated editor as standalone RCP supported in EMF 2.1.1? [message #396761 is a reply to message #396760] |
Thu, 10 November 2005 11:15  |
--------------040406060505010106080102
Adelino,
If export didn't complete properly then maybe the result is incomplete.
Any failures when running your application should typically appear in
the workspace/.metadata/.log, but I'm not so sure where that shows up
for RCP.
>app.
>Regards, Adelino.
>>Adelino,
>>exporting it?
>>>Hi,
>steps
>This
>issues
>process.
>>>Regards, Adelino.
<html>
<head>
</head>
Adelino,<br>
<br>
incomplete. Any failures when running your application should
typically appear in the workspace/.metadata/.log, but I'm not so sure
where that shows up for RCP.<br>
<br>
<br>
<blockquote cite="middkvq6j$8bt$1@news.eclipse.org" type="cite">
<pre wrap="">Running the editor without exporting works without any error.
app.
Regards, Adelino.
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:dkvj01$qjt$1@news.eclipse.org">news:dkvj01$qjt$1@news.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Adelino,
exporting it?
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->steps
</pre>
<pre wrap="">>from the "EMF goes RCP" article, the editor runs as an RCP application.
</pre>
</blockquote>
<pre wrap=""><!---->This
</pre>
<pre wrap="">is absolutely brilliant!
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->issues
</pre>
<pre wrap="">when exporting the .editor project :
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->process.
</pre>
<pre wrap="">2) The exported editor starts but when opening a model nothing happens
Regards, Adelino.
<a class="moz-txt-link-freetext" href=" http://www.eclipse.org/articles/Article-EMF-goes-RCP/rcp.htm l"> http://www.eclipse.org/articles/Article-EMF-goes-RCP/rcp.htm l</a>
<a class="moz-txt-link-freetext" href=" http://www.eclipse.org/articles/Article-RCP-1/tutorial1.html"> http://www.eclipse.org/articles/Article-RCP-1/tutorial1.html</a>
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------040406060505010106080102--
Current Time: Thu Sep 18 18:23:34 EDT 2025
Powered by FUDForum. Page generated in 0.02606 seconds
