Home » Modeling » EMF » ecore2ecore instances problem
ecore2ecore instances problem [message #392723] Mon, 09 May 2005 04:11 Go to next message
Originally posted by: dorothyww.hotmail.com
Hi, all,
I have established mappings between 2 ecore models. But I do not know how
to use it to migrate data from old ecore model to new ecore model. That
is, now I have the following items:
1. an .ecore2ecore file, containing the mapping details between ecore
model A->ecore model B
2. instances of ecore model A
I want to: get corresponding instances of ecore model B
Do I have to write a parser(java API) to map input details to output
details manually, or is there something I can refer to so that instances
of ecore model A will be automatically mapped to instances of ecore model
B? If yes, how to?
Thanks!
Re: ecore2ecore instances problem [message #392729 is a reply to message #392723] Mon, 09 May 2005 07:18 Go to previous messageGo to next message
The only built-in thing we are providing is that you can right click on
the .ecore2ecore file and invoke "Generate Ecore2XML" which can be used
to parse an instance of A directly into an instance of B. Kenn still
needs to document this stuff.
You may find other work such as Merlin or the model transformation work
useful to look at; links for them are at EMF Corner.
cww wrote:
> Hi, all,
> how to use it to migrate data from old ecore model to new ecore model.
> That is, now I have the following items:
> instances of ecore model A will be automatically mapped to instances
> of ecore model B? If yes, how to?
> Thanks!
Re: ecore2ecore instances problem [message #392780 is a reply to message #392729] Wed, 11 May 2005 22:08 Go to previous messageGo to next message
Can you tell me something on how to parse an instance of A directly into
an instance of B? As my project is urgent and I can not wait for several
months for Kenn's document...
Or can you tell me whether there's some classes in Ecore2XML that can be
used to parse an instance, similar to MappingEngineFactory or
IMappingSession in MTF?
Thank you very much!
Re: ecore2ecore instances problem [message #392782 is a reply to message #392729] Thu, 12 May 2005 03:17 Go to previous messageGo to next message
Hi Ed,
I can not find the the built in "Generate Ecore2XML" menue option. I tried
out in Package Explorer and the Navigator and looked in all the Ecore to
Ecore related menues.
Can you give me a hint?
Regards Philipp
"Ed Merks" <merks@ca.ibm.com> schrieb im Newsbeitrag
news:d5nhat$lr6$1@news.eclipse.org...
> the .ecore2ecore file and invoke "Generate Ecore2XML" which can be used to
> parse an instance of A directly into an instance of B. Kenn still needs
> cww wrote:
>> Hi, all,
>> B? If yes, how to?
>> Thanks!
Re: ecore2ecore instances problem [message #392783 is a reply to message #392782] Thu, 12 May 2005 03:54 Go to previous messageGo to next message
I found ecore2xml plugin: org.eclipse.emf.mapping.ecore2xml in emf's 2.1.0
version
you may also check it:-)
Re: ecore2ecore instances problem [message #392784 is a reply to message #392783] Thu, 12 May 2005 05:14 Go to previous messageGo to next message
Thank you,
needed to update my eclipse versions. Now I don't now how to invoke the
mapping of the instace files (what I understood is your problem too). If you
find any possiblity please let my know.
Philipp
"cww" <dorothyww@hotmail.com> schrieb im Newsbeitrag
news:46fa545fdac8c26a6c0baa92c6f3183b$1@www.eclipse.org...
>version
Re: ecore2ecore instances problem [message #392787 is a reply to message #392784] Thu, 12 May 2005 06:22 Go to previous messageGo to next message
--------------000401030405040001050305
Guys,
I haven't used this yet either, so rather than perhaps explain
incorrectly, I'll wait for Kenn to help out...
Philipp Seuring wrote:
>Thank you,
>Philipp
>>version
<html>
<head>
</head>
Guys,<br>
<br>
incorrectly, I'll wait for Kenn to help out...<br>
<br>
<br>
<blockquote cite="midd5v79u$j5g$1@news.eclipse.org" type="cite">
<pre wrap="">Thank you,
Philipp
"cww" <a class="moz-txt-link-rfc2396E" href="mailto:dorothyww@hotmail.com">&lt;dorothyww@hotmail.com&gt;</a> schrieb im Newsbeitrag
<a class="moz-txt-link-freetext" href="news:46fa545fdac8c26a6c0baa92c6f3183b$1@www.eclipse.org">news:46fa545fdac8c26a6c0baa92c6f3183b$1@www.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">I found ecore2xml plugin: org.eclipse.emf.mapping.ecore2xml in emf's 2.1.0
version
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------000401030405040001050305--
Re: ecore2ecore instances problem [message #392793 is a reply to message #392784] Thu, 12 May 2005 09:47 Go to previous messageGo to next message
Note that Ecore2XML is not meant to be used as a generic transformation
mechanism, but rather as a way to migrate data between two similar Ecore
models (e.g. two different versions of the same Ecore model). The basic idea
is that you can capture the mapping between the XML representation of one
model (version) and the Ecore representation of another model (version).
Ecore2XMLExtendedMetaData can be used to automatically map XML elements and
attributes to the classes and features of target Ecore representations based
on Ecore2XML mappings. Once your resource has been loaded, you can then make
use of a resource handler (post-processor) to take care of any additional
tranformations (migrations) that couldn't be described using the Ecore2XML
mapping.
For more information, the best I can do for now is point you to an example.
Take a look at the org.eclipse.uml2.examples.emof2ecore example (available
in CVS or as part of the UML2 examples feature), which demonstrates how a
simple transformation could be done between EMOF and Ecore...
Kenn
"Philipp Seuring" <philipp.seuring@lirmm.fr> wrote in message
news:d5v79u$j5g$1@news.eclipse.org...
> Thank you,
you
> Philipp
2.1.0
> >version
Re: ecore2ecore instances problem [message #392818 is a reply to message #392793] Fri, 13 May 2005 04:27 Go to previous messageGo to next message
Hi, Kenn,
I have taken a glance at the emof2ecore example, and have some problems,
needing helps...
I want to run this example, so I wrote a simple program to test it:
( I want to trace usage of Ecore2XMLExtendedMetaData)
public static void main(String[] args){
EMOF2EcoreResourceFactoryImpl factory = new
EMOF2EcoreResourceFactoryImpl();
Resource resource = factory.createResource(URI.createFileURI(new
File("????????????????????").getAbsolutePath()));
My problem is:
1. can you give me a sample input file to replace the "?????????????????"
in the above code? (I have no knowledge of EMOF, so it's too difficult for
me now to edit a sample file:-( )
2. still unclear about usage of Ecore2XMLExtendedMetaData, is there any
document except javadoc?
Thank you !!
cww
> mapping.
> Kenn
>> Thank you,
> you
>> Philipp
> 2.1.0
>> >version
Re: ecore2ecore instances problem [message #392822 is a reply to message #392818] Fri, 13 May 2005 05:50 Go to previous message
Philipp,
If your resource will have cross file references, you must load it into
a resource set so that the referenced resources can be demand loaded.
When running from main, you need to make sure you've looked at the FAQ
about running standalone since plugin.xml registrations won't happen
when running standalone. Folks often ask multiple times about
documentation; if we have it, you'll find it on the Documentation page
of the web site, and if its not there, it doesn't exist. You can
produce EMOF (.emof) file by editing a .ecore file and doing "Save as"
whatever.emof; this will serialize the Ecore as EMOF.
cww wrote:
> Hi, Kenn,
> problems, needing helps...
> Resource resource =
> My problem is:
> "?????????????????" in the above code? (I have no knowledge of EMOF,
> so it's too difficult for me now to edit a sample file:-( )
> any document except javadoc?
> Thank you !!
> cww
>> basic idea
>> one
>> elements and
>> then make
>> additional
>> Ecore2XML
>> mapping.
>> example.
>> (available
>> how a
>> Kenn
>>> Thank you,
>>> too). If
>> you
>>> Philipp
>> 2.1.0
>>> >version
Previous Topic:How I can enable "Open as EMF XMI"?
Next Topic:GenModel markImportLocation
Current Time: Wed Oct 15 08:08:19 EDT 2025
Powered by FUDForum. Page generated in 0.06283 seconds
