Home » Eclipse Projects » Eclipse Titan » Problems encoding SCCP LUDT (PDU_SCCP_LongUnitdata) with POINTERTO
Problems encoding SCCP LUDT (PDU_SCCP_LongUnitdata) with POINTERTO [message #1861089] Tue, 19 September 2023 15:25 Go to next message
Hi, I'm currently writing a test in TTCN3 which uses titan.ProtocolEmulations.SCCP [1] and I noticed the generated packet contains wrong pointer(1,2,3,4) values.
The test essentially submits an SCCP DULT with random data payload, something like:
template (value) PDU_SCCP ts_SCCP_LUDT(SCCP_PAR_Address calling, SCCP_PAR_Address called,
				      template (value) octetstring data,
				      template (value) BIT4 msg_hdl := '0000'B,
				      template (value) integer hop_ctr := 16) := {
	longudata := {
		messageType := ludt,
		protClass := {'0000'B, msg_hdl},
		hopCounter := hop_ctr,
		pointer1 := 0,  /* overwritten */
		pointer2 := 0,  /* overwritten */
		pointer3 := 0,  /* overwritten */
		pointer4 := 0,  /* overwritten */
		calledPAddress := ConvertASPAddressToEncodedAddress_itu(called),
		callingPAddress := ConvertASPAddressToEncodedAddress_itu(calling),
		longData := {
			paramLength := 0,
			data := data
		optionalPart := omit,
		eop := omit
testcase TC_process_rx_ludt() runs on SCCP_Test_RAW_CT {
	var SCCP_PAR_Address calling, called;
	var octetstring data := f_rnd_octstring(1000);
	f_init_raw(mp_sccp_cfg[0]);
	f_sleep(1.0);
	called := valueof(ts_SccpAddr_PC_SSN(mp_sccp_cfg[0].peer_pc, mp_sccp_cfg[0].peer_ssn,
					     mp_sccp_cfg[0].sio, mp_sccp_cfg[0].sccp_service_type));
	calling := valueof(ts_SccpAddr_PC_SSN(mp_sccp_cfg[0].own_pc, mp_sccp_cfg[0].own_ssn,
	f_send_sccp(ts_SCCP_XUDT(calling, called, data));
I think the other related types generate correct output (UDT, XUDT). The main difference between those and LUDT are:
* Pointers span 2 bytes instead of 1 (LIN2 vs LIN1)
* SCCP_param_LongData is used instead of SCCP_param_Data (which also has inside a length of 2 bytes instead of 1).
If I check with wireshark a packet I got from a production network, I see the following (see Pointer values):
Signalling Connection Control Part
    Message Type: Long Unitdata (0x13)
    .... 0000 = Class: 0x0
    0000 .... = Message handling: No special options (0x0)
    Hop Counter: 0x0f
    Pointer to first Mandatory Variable parameter: 7
    Pointer to second Mandatory Variable parameter: 10
    Pointer to third Mandatory Variable parameter: 13
    Pointer to Optional parameter: 0
    Called Party address (4 bytes)
        Address Indicator
            0... .... = Reserved for national use: 0x0
            .1.. .... = Routing Indicator: Route on SSN (0x1)
            ..00 00.. = Global Title Indicator: No Global Title (0x0)
            .... ..1. = SubSystem Number Indicator: SSN present (0x1)
            .... ...1 = Point Code Indicator: Point Code present (0x1)
        ..00 0100 1100 0100 = PC: 1220
        SubSystem Number: RANAP (142)
        [Linked to RANAP]
    Calling Party address (4 bytes)
        Address Indicator
        ..00 0011 1110 1001 = PC: 1001
        [Linked to RANAP]
with the TTCN3 generate packet, I see the following (see how pointer values are 1 value higher):
    Hop Counter: 0x10
    Pointer to first Mandatory Variable parameter: 8
    Pointer to second Mandatory Variable parameter: 11
    Pointer to third Mandatory Variable parameter: 14
    Called Party address (67 bytes)
    Calling Party address (67 bytes)
As you can see, in the TTCN3 case, the values encoded into the pointer fields are wrong (1 too high), and hence wireshark starts decoding the "Called Party address" 1 byte to far and everything looks wrong.
The record type from titan.ProtocolEmulations.SCCP is this one:
  type record  PDU_SCCP_LongUnitdata
    SCCP_param_MessageType               messageType,
    SCCP_param_ProtocolClass             protClass,
    SCCP_param_HopCounter                hopCounter,
    LIN2                                 pointer1,
    LIN2                                 pointer2,
    LIN2                                 pointer3,
    LIN2                                 pointer4,
    SCCP_param_CPartyAddressEnc          calledPAddress,
    SCCP_param_CPartyAddressEnc          callingPAddress,
    SCCP_param_LongData                  longData,
    SCCP_ExtUnitdata_optionalPart        optionalPart optional,
    SCCP_param_EndOfOptionalParams       eop   optional
   with { variant (pointer1) "POINTERTO(calledPAddress)";
          variant (pointer2) "POINTERTO(callingPAddress)";
          variant (pointer3) "POINTERTO(longData)";
          variant (pointer4) "POINTERTO(optionalPart)";
          variant "TAG (eop,paramName=con_SCCP_eop) "
I think there may be a bug with the implementation in titan of the POINTERTO with pointers spanning more than 1 byte. At least by looking at the reference guide [2] it's a big difficult to find out whether it starts counting after the entire pointer field, or from the start of it.
I tried playing with PTROFFSET to fix it, but I was unable to far. This change seems to leave the same behavior:
diff --git a/src/SCCP_Types.ttcn b/src/SCCP_Types.ttcn
index 2ae30e5..91f9e41 100644
--- a/src/SCCP_Types.ttcn
+++ b/src/SCCP_Types.ttcn
@@ -1249,9 +1249,13 @@ group PDUDefinitions
+          variant (pointer1) "PTROFFSET(1)";
+          variant (pointer2) "PTROFFSET(1)";
+          variant (pointer3) "PTROFFSET(1)";
+          variant (pointer4) "PTROFFSET(1)";
This also leaves the same behavior:
+          variant (pointer1) "PTROFFSET(pointer1)";
+          variant (pointer2) "PTROFFSET(pointer2)";
+          variant (pointer3) "PTROFFSET(pointer3)";
+          variant (pointer4) "PTROFFSET(pointer4)";
I also tried using PTROFFSET with the next field (eg
 variant (pointer2) "PTROFFSET(pointer1)";
, but then it goes wrong the other way: the value in the encoded packet becomes 1 byte too small.
I also tried using the following (which iiuc should works since the reference guide mentions "integers" are allowed), but ttcn3 fails to compile:
+          variant (pointer1) "PTROFFSET(-1)";
+          variant (pointer2) "PTROFFSET(-1)";
+          variant (pointer3) "PTROFFSET(-1)";
+          variant (pointer4) "PTROFFSET(-1)";
SCCP_Types.ttcn: In TTCN-3 module `SCCP_Types':
 SCCP_Types.ttcn:97.1-67: In external function definition `enc_PDU_SCCP':
  SCCP_Types.ttcn:97.31-48: In formal parameter list:
   SCCP_Types.ttcn:97.33-47: In parameter `pdu':
    SCCP_Types.ttcn:1314.3-1337.3: In type definition `PDU_SCCP':
     SCCP_Types.ttcn:1332.5-49: In union field `longudata':
      SCCP_Types.ttcn:1236.3-1250.4: In type definition `PDU_SCCP_LongUnitdata':
       SCCP_Types.ttcn:1252.41: error: in variant attribute, at or before token `-': syntax error
       SCCP_Types.ttcn:1254.41: error: in variant attribute, at or before token `-': syntax error
       SCCP_Types.ttcn:1256.41: error: in variant attribute, at or before token `-': syntax error
       SCCP_Types.ttcn:1258.41: error: in variant attribute, at or before token `-': syntax error
So at least I'd say the reference guide or the code has to be improved/fixes for the negative value scenario.
Any ideas or support is welcome. I attach the correct packet (from production network) and the TTCN3 generated one (with a random payload of 1000 bytes).
[1] https://gitlab.eclipse.org/eclipse/titan/titan.ProtocolEmulations.SCCP
[2] https://download.eclipse.org/titan/ReferenceGuide.pdf
[Updated on: Tue, 19 September 2023 15:35] by Moderator
Re: Problems encoding SCCP LUDT (PDU_SCCP_LongUnitdata) with POINTERTO [message #1861091 is a reply to message #1861089] Tue, 19 September 2023 15:58 Go to previous messageGo to next message
I have the feeling the
is somehow not applied to the generated C++ code. I'm using titan v8.3.0, and I see titan.core compiler in that version does for instance:
  if(raw_options[i].pointerto){   /* store the start of pointed field*/
    src=mputprintf(src,
      "  start_of_field%d=(int)field_%s%s+%d?1:-1;\n"
      ,sdef->elements[i].raw.pointerto
      ,sdef->elements[i].name,sdef->elements[i].isOptional?"()":""
      ,sdef->elements[i].raw.ptroffset
But looking at the generated code, sdef->elements[i].raw.ptroffset seems to be 0:
int PDU__SCCP__LongUnitdataService::RAW_decode(const TTCN_Typedescriptor_t& p_td, TTCN_Buffer& p_buf, int limit, raw_order_t top_bit_ord, boolean no_err, int, boolean, const RAW_Force_Omit* force_omit)
{ (void)no_err;
start_of_field7=(int)field_pointer1+0?1:-1;
Re: Problems encoding SCCP LUDT (PDU_SCCP_LongUnitdata) with POINTERTO [message #1861092 is a reply to message #1861089] Wed, 20 September 2023 02:22 Go to previous messageGo to next message
I'm checking the issue.
Meanwhile, set the PTROFFSET to 8 as it is counted as bits, not octets.
Re: Problems encoding SCCP LUDT (PDU_SCCP_LongUnitdata) with POINTERTO [message #1861094 is a reply to message #1861092] Wed, 20 September 2023 07:43 Go to previous messageGo to next message
Yes, the documentation is not clear about the details.
The value of the pointer field calculated as the difference between beginning of the pointer field and the beginning of the pointed field in bits, minus the ptr offset value, expressed in whole UNIT (which is 8 bit, octet by default).
The PTROFFSET is measured in bits.
Re: Problems encoding SCCP LUDT (PDU_SCCP_LongUnitdata) with POINTERTO [message #1861095 is a reply to message #1861094] Wed, 20 September 2023 08:00 Go to previous messageGo to next message
Hi Gabor,
I confirm the following change as you suggested seems to fix the encoding of the LUDT message:
index 2ae30e5..176b8f1 100644
+          variant (pointer1) "PTROFFSET(8)";
+          variant (pointer2) "PTROFFSET(8)";
+          variant (pointer3) "PTROFFSET(8)";
+          variant (pointer4) "PTROFFSET(8)";
Do you want me to submit a patch against titan.ProtocolEmulations.SCCP.git in gitlab? or are you already taking care of it yourself?
Re: Problems encoding SCCP LUDT (PDU_SCCP_LongUnitdata) with POINTERTO [message #1861096 is a reply to message #1861095] Wed, 20 September 2023 08:30 Go to previous messageGo to next message
Please submit a patch. Meanwhile the documentation of the TITAN will be updated.
Re: Problems encoding SCCP LUDT (PDU_SCCP_LongUnitdata) with POINTERTO [message #1861100 is a reply to message #1861096] Wed, 20 September 2023 09:57 Go to previous messageGo to next message
I submitted a PR here: https://gitlab.eclipse.org/eclipse/titan/titan.ProtocolEmulations.SCCP/-/merge_requests/3
Re: Problems encoding SCCP LUDT (PDU_SCCP_LongUnitdata) with POINTERTO [message #1861102 is a reply to message #1861100] Wed, 20 September 2023 10:09 Go to previous messageGo to next message
Thanks. It is merged now.
Re: Problems encoding SCCP LUDT (PDU_SCCP_LongUnitdata) with POINTERTO [message #1861112 is a reply to message #1861102] Thu, 21 September 2023 07:31 Go to previous messageGo to next message
Thanks! Let me know once you have updated the documentation, if you want I can read it and let you know if something is still not clear from reader/user point of view.
Re: Problems encoding SCCP LUDT (PDU_SCCP_LongUnitdata) with POINTERTO [message #1861113 is a reply to message #1861112] Thu, 21 September 2023 07:36 Go to previous message
You can check the changes in this MR: https://gitlab.eclipse.org/eclipse/titan/titan.core/-/merge_requests/360
Previous Topic:dynamic test case errors in 3GPP testsuite
Next Topic:LibSip codec for IMS
Current Time: Sat Oct 18 16:35:45 EDT 2025
Powered by FUDForum. Page generated in 0.03744 seconds
