Eclipse Helios Error when Debugging: "Error: Could not create the Java Virtual Machine." [message #1851858] |
Wed, 20 April 2022 08:04  |
I really need help with this as I cannot find a solution anywhere, having searched the internet and forums for a few weeks now!
I have a project in Eclipse Helios (Eclipse for RCP and RAP Developers Version Helios Service Release 2 Build id: 20110218-0911 running on Windows XP) which has been working fine, I can debug and run without any problems etc.
I have set up a new Windows 10 machine and I have exact same software versions and paths to the local drive for my project. As far as I can see, everything is identical.
However, when I use the Debug on the Windows 10 machine, I get the following error:
"Error: A fatal exception has occurred. Program will exit."
followed by:
'Launching ***.product' has encountered a problems.
Cannot connect to VM
(screenshots attached)
I have come across posts which suggest modifying the eclipse.ini file but they are all for solving the issue with Eclipse not launching rather than when Eclipse is working fine but the Debug has the issue.
I'm thinking that this is due to a setting within the Eclipse Platform or within Java settings? I'm running out of ideas!
Any help or suggestions with this would be very much appreciated.
Attachment: Error 1.png
(Size: 5.99KB, Downloaded 128 times)
Attachment: Error 2.png
(Size: 6.62KB, Downloaded 131 times)
Attachment: Eclipse.png
(Size: 28.09KB, Downloaded 136 times)
Attachment: Java.png
(Size: 6.42KB, Downloaded 146 times)
Re: Eclipse Helios Error when Debugging: "Error: Could not create the Java Virtual Machine.& [message #1851928 is a reply to message #1851927] |
Thu, 21 April 2022 14:42  |
I guess I just need to stick to my good old XP then! Thanks for all your suggestions but I'm not one for Upgrades! Even when I buy a brand new computer, I always switch off the Automatic Update and remove the actual Update Service from the Services. This is why my XP is still working and is still as fast as the first day I bought it! In my experience, every time I updated windows or any other software, everything starts to go wrong and there's no way of tracing what caused it! Even reverting back Upgrades, there's no guarantee to solve the new issues which could have been avoided! If it works, there's no need for upgrades, as you will be going down the road of the Unknown!
FUDForum. Page generated in 0.34167 seconds
