Could not run phased build action using connection to Gradle distribution [message #1843161] |
Fri, 16 July 2021 18:04  |
I got this error a couple hours ago and have tried about a million 'fixes' online no one which have worked:
Could not run phased build action using connection to Gradle distribution 'h.ttps://services.gradle.org/distributions/gradle-7.1.1-all.zip'.
Build file 'C:\Users\[User]\Documents\[ProjectName]\build.gradle' line: 10
A problem occurred evaluating root project '[ProjectName]'.
Failed to apply plugin 'net.minecraftforge.gradle'.
Found java version 16.0.1. Versions 16 and newer are not supported yet.
Note: Support for running under Java 16 requires Gradle 7, which will be supported in ForgeGradle 5.
It says that java version above 16 arent supported but that contradicts what it says on the website (17 and above arent supported yet) so I am very confused
FUDForum. Page generated in 0.05046 seconds
