| Home » Eclipse Projects » Eclipse Platform » Build from source problem(Could not resolve dependencies for project)
 Goto Forum:|
| Build from source problem [message #1840261] | Sat, 10 April 2021 08:46  |  |
| Eclipse User  |  |  |  |  | Hello! I wanted to build the Eclipse platform from the source codes for this manual: https://wiki.eclipse.org/Platform-releng/Platform_Build. Started building by checking dependencies (mvn -X clean validate) and got the following error:
[DEBUG] =======================================================================
[DEBUG] Could not find metadata org.eclipse.osgi:org.eclipse.osgi:3.16.300-SNAPSHOT/maven-metadata.xml in local (/home/main/.m2/repository)
[DEBUG] Dependency collection stats: {ConflictMarker.analyzeTime=78713, ConflictMarker.markTime=61270, ConflictMarker.nodeCount=2, ConflictIdSorter.graphTime=24137, ConflictIdSorter.topsortTime=40652, ConflictIdSorter.conflictIdCount=1, ConflictIdSorter.conflictIdCycleCount=0, ConflictResolver.totalTime=1380744, ConflictResolver.conflictItemCount=1, DefaultDependencyCollector.collectTime=5510133, DefaultDependencyCollector.transformTime=1819431}
[DEBUG] org.eclipse.osgi:org.eclipse.osgi.util:eclipse-plugin:3.6.0-SNAPSHOT
[DEBUG]    org.eclipse.osgi:org.eclipse.osgi:jar:3.16.300-SNAPSHOT:provided
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Summary:
[INFO]
[INFO] eclipse-platform-parent 4.20.0-SNAPSHOT ............ SUCCESS [  4.167 s]
[INFO] eclipse-sdk-prereqs 4.20.0-SNAPSHOT ................ SUCCESS [  0.371 s]
[INFO] eclipse jdt 4.20.0-SNAPSHOT ........................ SUCCESS [  0.362 s]
[INFO] rt.equinox.framework 4.20.0-SNAPSHOT ............... SUCCESS [  0.370 s]
[INFO] org.eclipse.osgi 3.16.300-SNAPSHOT ................. SUCCESS [ 11.336 s]
[INFO] org.eclipse.osgi.util 3.6.0-SNAPSHOT ............... FAILURE [  0.295 s]
[INFO] org.eclipse.osgi.services 3.10.100-SNAPSHOT ........ SKIPPED
[INFO] rt.equinox.bundles 4.20.0-SNAPSHOT ................. SKIPPED
[INFO] org.eclipse.equinox.common 3.14.100-SNAPSHOT ....... SKIPPED
[ERROR] Failed to execute goal on project org.eclipse.osgi.util: Could not resolve dependencies for project org.eclipse.osgi:org.eclipse.osgi.util:eclipse-plugin:3.6.0-SNAPSHOT: Could not find artifact org.eclipse.osgi:org.eclipse.osgi:jar:3.16.300-SNAPSHOT -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal on project org.eclipse.osgi.util: Could not resolve dependencies for project org.eclipse.osgi:org.eclipse.osgi.util:eclipse-plugin:3.6.0-SNAPSHOT: Could not find artifact org.eclipse.osgi:org.eclipse.osgi:jar:3.16.300-SNAPSHOT
I post the logs and pom.xml from the root
 Thanks for attention!
 Attachment: logs.txt (Size: 5.56MB, Downloaded 202 times)
 Attachment: pom.xml (Size: 2.38KB, Downloaded 225 times)
| Re: Build from source problem [message #1844600 is a reply to message #1840280] | Fri, 17 September 2021 05:45   |  |
| Eclipse User  |  |  |  |  | Hello! was there a solution to this? I am having a similar issue.
 [DEBUG] Could not find metadata org.eclipse.osgi:org.eclipse.osgi:3.16.200-SNAPSHOT/maven-metadata.xml in local (C:\Users\user\.m2\repository)
 Long:
 [INFO] ---------------< org.eclipse.osgi:org.eclipse.osgi.util >---------------
[INFO] Building org.eclipse.osgi.util 3.6.0-SNAPSHOT                   [60/501]
[INFO] ---------------------------[ eclipse-plugin ]---------------------------
[DEBUG] Resolving plugin prefix dependency from [org.apache.maven.plugins, org.codehaus.mojo]
[DEBUG] Resolved plugin prefix dependency to org.apache.maven.plugins:maven-dependency-plugin from POM org.eclipse.osgi:org.eclipse.osgi.util:eclipse-plugin:3.6.0-SNAPSHOT
[DEBUG] Lifecycle default -> [validate, initialize, generate-sources, process-sources, generate-resources, process-resources, compile, process-classes, generate-test-sources, process-test-sources, generate-test-resources, process-test-resources, test-compile, process-test-classes, test, prepare-package, package, pre-integration-test, integration-test, post-integration-test, verify, install, deploy]
[DEBUG] Lifecycle clean -> [pre-clean, clean, post-clean]
[DEBUG] Lifecycle site -> [pre-site, site, post-site, site-deploy]
[DEBUG] === PROJECT BUILD PLAN ================================================
[DEBUG] Project:       org.eclipse.osgi:org.eclipse.osgi.util:3.6.0-SNAPSHOT
[DEBUG] Dependencies (collect): []
[DEBUG] Dependencies (resolve): [test]
[DEBUG] Repositories (dependencies): [eclipse (https://download.eclipse.org/eclipse/updates/4.19/R-4.19-202103031800/, p2, disa-bled), central (https://repo.maven.apache.org/maven2, default, releases)]
[DEBUG] Repositories (plugins)     : [tycho-snapshots (https://repo.eclipse.org/content/repositories/tycho-snapshots/, default, releas-es+snapshots), cbi-jdt (https://repo.eclipse.org/content/repositories/eclipse-staging/, default, releases+snapshots), cbi-snapshots (https://repo.eclipse.org/content/repositories/cbi-snapshots/, default, releas-es+snapshots), cbi-releases (https://repo.eclipse.org/content/repositories/cbi-releases/, default, releases+snapshots), eclipse (https://repo.eclipse.org/content/repositories/cbi/, default, releases+snapshots), central (https://repo.maven.apache.org/maven2, default, releases)]
[DEBUG] -----------------------------------------------------------------------
[DEBUG] Goal:          org.apache.maven.plugins:maven-dependency-plugin:2.8:tree (de-fault-cli)
[DEBUG] Style:         Regular
[DEBUG] Configuration: <?xml version="1.0" encoding="UTF-8"?>
<configuration>
  <appendOutput default-value="false">${appendOutput}</appendOutput>
  <excludes>${excludes}</excludes>
  <includes>${includes}</includes>
  <localRepository default-value="${localRepository}"/>
  <output>${output}</output>
  <outputFile>${outputFile}</outputFile>
  <outputType default-value="text">${outputType}</outputType>
  <scope>${scope}</scope>
  <skip default-value="false">${skip}</skip>
  <tokens default-value="standard">${tokens}</tokens>
  <verbose default-value="false">${verbose}</verbose>
  <project default-value="${project}"/>
</configuration>
[DEBUG] Dependency collection stats {ConflictMarker.analyzeTime=11101, ConflictMark-er.markTime=8700, ConflictMarker.nodeCount=2, ConflictIdSorter.graphTime=3900, Con-flictIdSorter.topsortTime=8400, ConflictIdSorter.conflictIdCount=1, ConflictIdSort-er.conflictIdCycleCount=0, ConflictResolver.totalTime=91400, ConflictResolv-er.conflictItemCount=1, DefaultDependencyCollector.collectTime=1519601, DefaultDepend-encyCollector.transformTime=147199}
[DEBUG]    org.eclipse.osgi:org.eclipse.osgi:jar:3.16.200-SNAPSHOT:provided
[INFO]
[INFO] Skipping org.eclipse.equinox.common
[INFO] This project has been banned from the build due to previous failures.
 Current Time: Fri Oct 31 02:11:22 EDT 2025
 Powered by FUDForum . Page generated in 0.09255 seconds |
