ConcurrencyManager.releaseDeferredLock [message #1751649] |
Thu, 12 January 2017 04:24  |
We are getting a lot of stuck thread in our production environment. We have to restart the server, once the queries are stuck. Basically we are using EclipseLink 2.4.1 in a J2EE stack with WebLogic 10.3.6. We often have a lot of "stuck threads", caused by lines in EclipseLink that are getting releaseDeferred locks in concurrency manager. using JPA
11-Jan-2017 15:42:09.408 INFO [main] org.apache.catalina.core.StandardServer.await A valid shutdown command was received via the shutdown port. Stopping the Server instance.
11-Jan-2017 15:42:09.408 INFO [main] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["http-nio-8080"]
11-Jan-2017 15:42:09.459 INFO [main] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["ajp-nio-8009"]
11-Jan-2017 15:42:09.510 INFO [main] org.apache.catalina.core.StandardService.stopInternal Stopping service Catalina
11-Jan-2017 15:42:09.553 INFO [localhost-startStop-2] org.apache.catalina.core.StandardWrapper.unload Waiting for 12 instance(s) to be deallocated for Servlet [Faces Servlet]
11-Jan-2017 15:42:10.555 INFO [localhost-startStop-2] org.apache.catalina.core.StandardWrapper.unload Waiting for 12 instance(s) to be deallocated for Servlet [Faces Servlet]
11-Jan-2017 15:42:11.556 INFO [localhost-startStop-2] org.apache.catalina.core.StandardWrapper.unload Waiting for 12 instance(s) to be deallocated for Servlet [Faces Servlet]
11-Jan-2017 15:42:11.709 WARNING [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesJdbc The web application [ROOT] registered the JDBC driver [com.mysql.jdbc.Driver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered.
11-Jan-2017 15:42:11.710 WARNING [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [ROOT] is still processing a request that has yet to finish. This is very likely to create a memory leak. You can control the time allowed for requests to finish by using the unloadDelay attribute of the standard Context implementation. Stack trace of request processing thread:
java.lang.Thread.sleep(Native Method)
org.eclipse.persistence.internal.helper.ConcurrencyManager.releaseDeferredLock(ConcurrencyManager.java:445)
org.eclipse.persistence.internal.identitymaps.CacheKey.releaseDeferredLock(CacheKey.java:465)
org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:1070)
org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildWorkingCopyCloneNormally(ObjectBuilder.java:899)
org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObjectInUnitOfWork(ObjectBuilder.java:852)
org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:735)
org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:689)
org.eclipse.persistence.queries.ObjectLevelReadQuery.buildObject(ObjectLevelReadQuery.java:805)
org.eclipse.persistence.queries.ReadAllQuery.registerResultInUnitOfWork(ReadAllQuery.java:962)
org.eclipse.persistence.queries.ReadAllQuery.executeObjectLevelReadQuery(ReadAllQuery.java:573)
org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:1175)
org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:904)
org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:1134)
org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAllQuery.java:460)
org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1222)
org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2896)
org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1857)
org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1839)
org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1804)
org.eclipse.persistence.internal.jpa.QueryImpl.executeReadQuery(QueryImpl.java:258)
org.eclipse.persistence.internal.jpa.QueryImpl.getSingleResult(QueryImpl.java:521)
org.eclipse.persistence.internal.jpa.EJBQueryImpl.getSingleResult(EJBQueryImpl.java:400)
com.bst.orasis.dal.UserCompanySelectionDAO.findByUserName(UserCompanySelectionDAO.java:31)
com.bst.orasis.service.UserCompanySelectionService.findByUserName(UserCompanySelectionService.java:72)
com.bst.orasis.dal.BaseService.getLoggedUserCompanySelectioEntity(BaseService.java:266)
com.bst.orasis.dal.BaseService.setLoggedInUserEntity(BaseService.java:188)
com.bst.orasis.dal.BaseService.<init>(BaseService.java:167)
com.bst.orasis.ui.portal.ServiceBean.<init>(ServiceBean.java:15)
sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
java.lang.reflect.Constructor.newInstance(Constructor.java:423)
java.lang.Class.newInstance(Class.java:442)
com.sun.faces.mgbean.BeanBuilder.newBeanInstance(BeanBuilder.java:186)
com.sun.faces.mgbean.BeanBuilder.build(BeanBuilder.java:100)
com.sun.faces.mgbean.BeanManager.createAndPush(BeanManager.java:409)
com.sun.faces.mgbean.BeanManager.create(BeanManager.java:269)
com.sun.faces.el.ManagedBeanELResolver.resolveBean(ManagedBeanELResolver.java:257)
com.sun.faces.el.ManagedBeanELResolver.getValue(ManagedBeanELResolver.java:117)
com.sun.faces.el.DemuxCompositeELResolver._getValue(DemuxCompositeELResolver.java:176)
com.sun.faces.el.DemuxCompositeELResolver.getValue(DemuxCompositeELResolver.java:203)
org.apache.el.parser.AstIdentifier.getValue(AstIdentifier.java:94)
org.apache.el.ValueExpressionImpl.getValue(ValueExpressionImpl.java:184)
com.sun.faces.mgbean.BeanBuilder$Expression.evaluate(BeanBuilder.java:561)
com.sun.faces.mgbean.ManagedBeanBuilder$BakedBeanProperty.set(ManagedBeanBuilder.java:606)
com.sun.faces.mgbean.ManagedBeanBuilder.buildBean(ManagedBeanBuilder.java:133)
com.sun.faces.mgbean.BeanBuilder.build(BeanBuilder.java:102)
org.apache.el.parser.AstValue.getValue(AstValue.java:137)
com.sun.faces.facelets.el.ELText$ELTextVariable.writeText(ELText.java:238)
com.sun.faces.facelets.el.ELText$ELTextComposite.writeText(ELText.java:154)
com.sun.faces.facelets.compiler.TextInstruction.write(TextInstruction.java:85)
com.sun.faces.facelets.compiler.UIInstructions.encodeBegin(UIInstructions.java:82)
com.sun.faces.facelets.compiler.UILeaf.encodeAll(UILeaf.java:183)
javax.faces.component.UIComponent.encodeAll(UIComponent.java:1859)
com.sun.faces.application.view.FaceletViewHandlingStrategy.renderView(FaceletViewHandlingStrategy.java:458)
com.sun.faces.application.view.MultiViewHandler.renderView(MultiViewHandler.java:134)
com.sun.faces.lifecycle.RenderResponsePhase.execute(RenderResponsePhase.java:120)
com.sun.faces.lifecycle.Phase.doPhase(Phase.java:101)
com.sun.faces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:219)
javax.faces.webapp.FacesServlet.service(FacesServlet.java:659)
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:292)
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207)
org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240)
com.bst.orasis.entities.userauth.UserAuthFilter.doFilter(UserAuthFilter.java:57)
org.jasig.cas.client.util.HttpServletRequestWrapperFilter.doFilter(HttpServletRequestWrapperFilter.java:62)
org.jasig.cas.client.validation.AbstractTicketValidationFilter.doFilter(AbstractTicketValidationFilter.java:196)
org.jasig.cas.client.authentication.AuthenticationFilter.doFilter(AuthenticationFilter.java:93)
org.jasig.cas.client.session.SingleSignOutFilter.doFilter(SingleSignOutFilter.java:65)
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:212)
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
org.apache.catalina.valves.RemoteIpValve.invoke(RemoteIpValve.java:676)
org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:616)
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:528)
org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1099)
org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:672)
org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1520)
org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1476)
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
java.lang.Thread.run(Thread.java:745)
Re: ConcurrencyManager.releaseDeferredLock [message #1758326 is a reply to message #1756471] |
Mon, 27 March 2017 13:02  |
Have you gone through the http://wiki.eclipse.org/EclipseLink/FAQ/JPA#How_to_diagnose_and_resolve_hangs_and_deadlocks.3F FAQ? You will need to gather the thread dump, and it would help to look at what the code involved in the lock is doing, and evaluate the other threads as I do not believe this is a true deadlock.
In this case, two or more threads are operating on the same object graph, attempting to build or write to it at the same time. This thread that gets stuck is simply waiting for some other thread to finish building the object graph, and WLS is timing it out believing it is stuck. It maybe stuck, or you are just experiencing a bottleneck on a particular object or graph in the shared cache due to options (like read-only, always refresh or other settings) that causes thread issues under load or less ideal circumstances.
FUDForum. Page generated in 0.02725 seconds
