| PartSashContainter - set partSize in px [message #1695323] |
Wed, 13 May 2015 09:24  |
I add:
<children xsi:type="basic:PartSashContainer" xmi:id="_4IN2EPlxEeSJ7MGbdT-fCQ" elementId="test11.app.partsashcontainer.0" horizontal="true">
<children xsi:type="basic:Part" xmi:id="_4j6TkPlxEeSJ7MGbdT-fCQ" elementId="test11.app.part.0" containerData="1000"/>
<children xsi:type="basic:Part" xmi:id="_5VvZIPlxEeSJ7MGbdT-fCQ" elementId="test11.app.part.1" containerData="99000"/>
</children> in theory the containterData sets as %. But when I change width of the trimmedWindow, the divider posision isn't the same (but change windowWidht, not containerData).
2.
I set in the first part containter data 100, second containter data 900, but first part takes more than 10%...
________________
I want to set 1st panel in px (even in addon at start), but I don't known, what I must put in the container data, or maybe there is other solution?
| Re: PartSashContainter - set partSize in px [message #1695329 is a reply to message #1695323] |
Wed, 13 May 2015 09:37   |
a) PartSashContainer uses a SplitPane and we calculate the value you
provide to spitter positions (see
DefSashRenderer.WResizeableSash#doRecalc)
b) the resize behavior is the SplitPane uses it so if the SplitPane is
resized the children will be resized as well so it will resize all
children (a guess I have is that setResizableWithParent could fix
that?)
You can check the code if our calculation is invalid but SplitPane is a
bit of a pain because eg on initial layout it sometime behaves really
strange.
c) It looks like you want to have a fixed layout so then you
fx_fixedLayout, fx_layout_width, ... sounds like what you are
looking for see
https://wiki.eclipse.org/Efxclipse/Runtime/e4#MPartSashContainer
Tom
On 13.05.15 15:24, Bart Cichy wrote:
> Hello,
> 1.
> I add:
> </children>in theory the containterData sets as %. But when I change
> 2.
> ________________
> solution?
> Regards
| Re: PartSashContainter - set partSize in px [message #1695332 is a reply to message #1695329] |
Wed, 13 May 2015 09:47  |
once more in proper english
provided to splitter positions (see
b) the resize behavior is inherited from SplitPane so if the width is
changed all children will get more space, it might be that
SplitPane#setResizableWithParent could fix that?
You can check the code of our calculation is invalid but SplitPane but I
know that SplitPane sometime behaves very strange eg when the Stage is
rendered the first time and the Scene does not yet have the real size.
looking for see
Tom
> that?)
> strange.
> looking for see
> Tom
>> Hello,
>> 1.
>> I add:
>> 2.
>> ________________
>> solution?
>> Regards
FUDForum. Page generated in 0.03423 seconds
