Home » Modeling » Compare » How to integrate emf compare with eclipse team support?
How to integrate emf compare with eclipse team support? [message #996498] |
Wed, 02 January 2013 03:21  |
Adding team plugin in your eclipse plugin project will enable team, compare with and so on options in your project explorer. What I want to do is, when I right click on my persisted model file (xmi file format), choose "compare with latest from repository", the emf compare editor should show me the changes between my local version and one stored on svn server. However, the emf compare editor shows "no differences" while default text compare shows them correctly.
I would like to ask whether adding this kind of native version control support through eclipse team to xmi file is possible at the moment and if yes, how to do it?
Re: How to integrate emf compare with eclipse team support? [message #996940 is a reply to message #996498] |
Thu, 03 January 2013 03:53   |
I had started answering this on stackoverflow. See the question there for details, but here is a small abstract of the discussion we started over there :
Wakandan
How can we tell EMF Compare to trigger when comparing files with a given extension? The content-type org.eclipse.emf.compare.ui.contenttype.ModelContentType no longer exists with EMF Compare 2.
I tried adding a file-type association between my custom file extension and the org.eclipse.emf.ecore.xmi content-type so that emf compare could pick up my file and do the diff automatically. This way, the emf model compare editor shows up but it says there's no differences even though I pretty sure I made some changes to the model. What should I do?
Laurent Goubet
EMF Compare is called from the platform if the content-type matches, whether you're using compare with > each other or compare with > latest from repository... or any other does not matter.
With EMF Compare 2, we have yet to re-add a custom content-type, but you can achieve the same result with the org.eclipse.emf.ecore.xmi extension, which you have done.
compare with > latest from repository not showing any difference means that we have failed to retrieve the proper "remote" content for your file. you can switch back to text comparison (from the model compare editor) with the drop-down menu at the center that shows "EMF Compare" : just select "text compare" in there. There, you should see the textual differences between your files : if there are none, then we indeed failed to retrieve the proper remote content (or you actually have no difference between the local and remote files).
If that is the case, do you have anything that shows up in your error log (Window > Show View > Error Log)? What repository are you using, CVS? Is your comparison actually showing textual differences between your files when you disable EMF Compare altogether?
Wakandan
While emf compare editor shows no difference, the textual compare editor did show changes between local v.s remote file. In this case, what should I do? Debugging into the action "compare with latest from repo" shows me that the diff was done on the server side, and the input into emf compare editor was a list of svndiff thingy
[Updated on: Thu, 03 January 2013 03:54] by Moderator
Re: How to integrate emf compare with eclipse team support? [message #996974 is a reply to message #996963] |
Thu, 03 January 2013 05:20   |
Quote:file revision of left/right/origin could not be resolved (SVNRevision doesn't implement the same IFileRevision interface, I suspect)
That's what I expected. The IFileRevision is there, somewhere, but we need a specific workaround to find it. One way or another, subversive needs to integrate itself with the Eclipse Team APIs, and it is that API that EMF Compare uses in order to make sense of the repository specific information. That's the goal of EMFSynchronizationModel#findFileRevision(ITypedElement), but obviously the tricks I use for EGit and CVS are not sufficient for subversive (or subclipse, whichever you're using).
Quote:May I ask why we can't reduce everything into just 1 case of comparing 2 emf models? In the end, whether it's svn, csv or git they are all resources. As long as EMF compare got a pair of resources it should be good to go right?
That is unfortunately not the case. EGit, CVS, Subclipse, Subversive, Clearcase ... none of them implements the Team APIs the same way. The goal of EMFSynchronizationModel _is_ to try and make some sense out of this mess, and precisely reduce the case to just "comparing n revisions". But to this end we still need to find a way to handle the distinct information we are fed by the distinct repository providers.
Note, too, that you are not "comparing 2 models" but in fact comparing 3 models : your local version, the latest version from the SVN repository, and the common ancestor of these two. The presence of the ancestor is what allows comparison algorithms to detect conflicts.
Furthermore, EMF resources are not only "1 file each" : each EMF model can reference others (model fragments, dependencies...), and we need to "find" these others in order to properly compare the resources. That is why we load a full resource set, even if in your case there are no other dependencies, we still need to determine the remote revisions' contents. You might find the description of what is a logical model instructive.
Laurent Goubet
Obeo
Re: How to integrate emf compare with eclipse team support? [message #997160 is a reply to message #997150] |
Fri, 04 January 2013 02:55  |
Any direction of how to fix that? EMF Compare to me is so great, make working with emf a breeze. I suppose the fix (if any) would be adapters for each of version control systems?
As mentionned above, the way to fix this will be to implement the necessary case within EMFSynchronizationModel#findFileRevision(ITypedElement) for it to adapt the SVN revisions to IFileRefevisions. What we currently have works for CVS and EGit, but it will need tweaking for the SVN plugins. One of the main problematic points is that we do not (neither do we want to) depend on those plugins, and so cannot use subversive specific code to adapt the revisions.
We have other priorities at the moment though, so making EMF Compare work with subversive/subclipse will come at a later time (we still have a lot to stabilize from the switch to version 2.*). Please raise a bug on the eclipse bugzilla to track the issue.
Btw is it possible if I could update the emf compare documentation with some examples taking from what I'm working on?
The documentation is a wiki, feel free to edit it with your own examples if you think you have samples that could help others (maybe make an examples section with the description of the issues you've faced and how you fixed them?). Take good note that we'll do a good overhaul of the doc ourselves as soon as the current issues we're working on are fixed, so the contents and links between pages will most likely change.
Laurent Goubet
Obeo
Current Time: Sat Jul 26 20:06:23 EDT 2025
Powered by FUDForum. Page generated in 0.04996 seconds
