Home » Language IDEs » Java Development Tools (JDT) » Can't Find javac on Windows
Can't Find javac on Windows [message #991414] Tue, 18 December 2012 19:28 Go to next message
I have an ant XML that I am trying to use to create my jar file. However, when I run it I get this error:
BUILD FAILED
H:\html\Applets\KCBSEvents\makejar.xml:56: Unable to find a javac compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK.
It is currently set to "C:\Program Files\Java\jre7"
Clearly JAVA_HOME is pointing to the wrong directory. Is should be C:\Program Files\Java\jdk1.7.0_10. Unfortunately I cannot find where that is set. It is not in the Win 7 environment variables and even adding it does not help. Where in Eclipse is that set so I can fix it? TIA.
Re: Can't Find javac on Windows [message #994452 is a reply to message #991414] Thu, 27 December 2012 05:50 Go to previous messageGo to next message
You will need to have the latest JDK (1.6) installed as well. Can you try executing "javac" from the command line?
Re: Can't Find javac on Windows [message #994888 is a reply to message #994452] Fri, 28 December 2012 10:10 Go to previous message
Thanks for the reply. I can but only from the bin directory. For some reason the installer did not add it to the PATH variable which I thought it would have.
[Updated on: Fri, 28 December 2012 10:10] by Moderator
Previous Topic:Override cannot be resolved to a type
Next Topic:Assertion Error Breakpoint
Current Time: Fri Jul 25 07:28:11 EDT 2025
Powered by FUDForum. Page generated in 0.05757 seconds
