Home » Eclipse Projects » Eclipse 4 » @Focus in Eclipse 4.3 M3
@Focus in Eclipse 4.3 M3 [message #986413] Tue, 20 November 2012 06:00 Go to next message
today I installed Eclipse 4.3 M3. On trying to run the application I migrated to Eclipse 4 I noticed a different behaviour for @Focus. It seems the call stack has changed and @Focus is called before @PostConstruct. This leads to a NPE if I'm trying to do something like this (got this from some well known tutorials):
private TableViewer viewer;
@PostConstruct
public void createPart(Composite parent) {
	viewer = new TableViewer(composite, SWT.BORDER | SWT.H_SCROLL | SWT.V_SCROLL | SWT.FULL_SELECTION);
@Focus
public void setFocus() {
	viewer.getTable().setFocus();
This code works with 4.2.1. So the question is, is the new behaviour intended or a bug?
Greez,
Dirk
Re: @Focus in Eclipse 4.3 M3 [message #986415 is a reply to message #986413] Tue, 20 November 2012 06:03 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=394327
Re: @Focus in Eclipse 4.3 M3 [message #986416 is a reply to message #986415] Tue, 20 November 2012 06:12 Go to previous messageGo to next message
Thanks Sopot, that's it. Again I searched with the wrong parameters. Sad
Re: @Focus in Eclipse 4.3 M3 [message #986758 is a reply to message #986416] Wed, 21 November 2012 09:46 Go to previous messageGo to next message
Dirk, I just pushed Wims change. Would be great if you could test the fix and perhaps comment on the bug.
Re: @Focus in Eclipse 4.3 M3 [message #986761 is a reply to message #986758] Wed, 21 November 2012 09:59 Go to previous messageGo to next message
As far as I understand, the fix is to add the dependency to javax.annotation on creating a new project. So for existing projects, this wouldn't fix anything. There needs to be a documentation on what to do on moving from 4.2 to 4.3.
Or did I missunderstand the fix?
Re: @Focus in Eclipse 4.3 M3 [message #986771 is a reply to message #986761] Wed, 21 November 2012 10:15 Go to previous messageGo to next message
Just change your MANIFEST.MF dependency to a package dependency for javax.annotation and re-run.
Re: @Focus in Eclipse 4.3 M3 [message #986774 is a reply to message #986771] Wed, 21 November 2012 10:25 Go to previous messageGo to next message
Yes I did that already after Sopot linked to the bug. Smile And yes then it works. Nevertheless this needs to be documented as a migration issue for existing Eclipse 4 applications.
Re: @Focus in Eclipse 4.3 M3 [message #986775 is a reply to message #986774] Wed, 21 November 2012 10:27 Go to previous messageGo to next message
-> Sure, go ahead. Smile
Re: @Focus in Eclipse 4.3 M3 [message #988798 is a reply to message #986413] Mon, 03 December 2012 04:25 Go to previous messageGo to next message
I just stumbled upon this problem, and could fix it by adding the proposed @Inject after the @PostConstruct
If I execute the code on 4.3 it at least works, if I execute it on 4.2 now, however, the user interface elements get shown doubled!!
I don't get this, what is now the official solution? I am using the latest 4.3 I and 4.2 and I don't seem to be able to create a version that runs flawless on both?!
Re: @Focus in Eclipse 4.3 M3 [message #988799 is a reply to message #988798] Mon, 03 December 2012 04:35 Go to previous messageGo to next message
As Lars explained, you need to add the depencency to javax.annotation package to your MANIFEST.MF. You don't need to have @Inject and @PostConstruct at the same time.
Re: @Focus in Eclipse 4.3 M3 [message #988810 is a reply to message #988799] Mon, 03 December 2012 05:13 Go to previous messageGo to next message
Am 03.12.12 10:35, schrieb Dirk Fauth:
Don't need is the wrong term! MUST NOT is the correct one.
In the end the real problem is that equinox by default exports all the
bootclasspath-packages. If you'd have pure OSGi you'd import each and
every package no matter if it is provided as part of the JDK (=exported
by the system.bundle) or another bundle and PDE replicates this :-(
It would be nice to put PDE into a strict OSGi-mode where it tells you
that you need to import the bits from the JRE as well.
Tom
Re: @Focus in Eclipse 4.3 M3 [message #988823 is a reply to message #988799] Mon, 03 December 2012 05:58 Go to previous messageGo to next message
I already have that dependency, it does not help!
Re: @Focus in Eclipse 4.3 M3 [message #988828 is a reply to message #988823] Mon, 03 December 2012 06:08 Go to previous messageGo to next message
Please note that it should be a package-import and not a require-bundle.
Tom
Am 03.12.12 11:58, schrieb Marco Descher:
Re: @Focus in Eclipse 4.3 M3 [message #988830 is a reply to message #988828] Mon, 03 December 2012 06:19 Go to previous message
That did it, thanks a lot Smile
Previous Topic:Mechanism to provide IAdapterFactory for classes, not instances?
Next Topic:Contacts Demo not working properly
Current Time: Wed Jul 23 20:38:35 EDT 2025
Powered by FUDForum. Page generated in 0.06243 seconds
