Home » Eclipse Projects » GEF » Autoscroll when moving (dragging) objects
Autoscroll when moving (dragging) objects [message #97647] Tue, 07 October 2003 04:56 Go to next message
Originally posted by: g.wagenknecht.intershop.de
Hi!
Our editor doesn't scroll when we move/drag an object out of its visible
range. Only the scrollbars are modified. Is it possible to move the visible
area (autoscroll) according to the new position?
Cu, Gunnar
Re: Autoscroll when moving (dragging) objects [message #97662 is a reply to message #97647] Tue, 07 October 2003 06:35 Go to previous messageGo to next message
> visible range. Only the scrollbars are modified. Is it possible to
> move the visible area (autoscroll) according to the new position?
Ok, got it. It works partially (not the usual Windows way). I opened a
bugzilla to track further improvements.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=44288
Cu, Gunnar
Re: Autoscroll when moving (dragging) objects [message #97721 is a reply to message #97662] Tue, 07 October 2003 09:55 Go to previous messageGo to next message
"Gunnar Wagenknecht" <g.wagenknecht@intershop.de> wrote in message
news:blu4tp$ucr$1@eclipse.org...
Maybe you should check windows behavior again? Try dragging a folder inside
the tree of the Windows Explorer.
> Cu, Gunnar
Re: Autoscroll when moving (dragging) objects [message #97853 is a reply to message #97721] Wed, 08 October 2003 02:39 Go to previous messageGo to next message
> inside the tree of the Windows Explorer.
Yes, I noticed. But have you checked Word? They have a similar behavior but
the region where auto-scrolling starts is a bit lager than the one in the
GEF viewer and it starts as soon as you enter this region. In GEF you have
to wait a little bit in that region. Also scrollings gets faster the closer
you get to the border.
Cu, Gunnar
Re: Autoscroll when moving (dragging) objects [message #198342 is a reply to message #97853] Mon, 10 October 2005 14:37 Go to previous message
> Cu, Gunnar
PMFYI
AFAIK Word has its own Mangement for that behaviour and does not rely on
Windows behaviour.
kind regards
Astrid
Previous Topic:Beehive Application Wizard Startup
Next Topic:GEF TreeViewer upgrade
Current Time: Sat Aug 30 22:50:12 EDT 2025
Powered by FUDForum. Page generated in 0.04715 seconds
