enriching code with ocl [message #975206] |
Wed, 07 November 2012 12:44  |
hi,
I want to enrich my code with ocl in EMF, juno. so, I wrote the OCLs in ecore file and generated the code after that. but no where in the methods of class,my conditions are considered.for example I wrote:
operation deleteFolder(fPath : String[?] { ordered })
precondition C3: self.folders.subfolders->size() + self.folders.tasks->size() = 0;
would you please help me?
Re: enriching code with ocl [message #975660 is a reply to message #975382] |
Wed, 07 November 2012 21:08   |
Thank you so much for your reply. I have noticed that only the codes for invariants are created and no where in the generated code it has been used. So, I think I need to call the validate function manually myself. I have no clue what should I pass for the parameter, any helps? here the piece of code for the constraints:
public boolean validateTask_C2(Task task, DiagnosticChain diagnostics, Map<Object, Object> context) {
return
validate
(TmsPackage.Literals.TASK,
task,
diagnostics,
context,
"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot",
"C2",
TASK__C2__EEXPRESSION,
Diagnostic.ERROR,
DIAGNOSTIC_SOURCE,
0);
Best
Re: enriching code with ocl [message #975865 is a reply to message #975660] |
Thu, 08 November 2012 01:03   |
HI
The validation code is invoked by the standard EMF validation framework,
so the call-path is obscured by the EValidator regustration.
You have probably neglected to register the validation delegates as
described in the standalone setup documentation, but since you provide
no details I can only guess.
Ed Willink
> return
> validate
> task,
> diagnostics,
> context,
> "C2",
> Diagnostic.ERROR,
> DIAGNOSTIC_SOURCE,
> 0);
> Best
Re: enriching code with ocl [message #977306 is a reply to message #976720] |
Fri, 09 November 2012 02:06  |
Help->Help Contents->OCL Documention.
or just Google: Eclipse OCL Validate Delegate
Ed Willink
On 08/11/2012 20:04, Jeni Martin wrote:
> hi Ed,
> By the way, Where can I find that documentation? I didn't register as
> I didn't know what should I do with this generated code.
FUDForum. Page generated in 0.04185 seconds
