Home » Eclipse Projects » Equinox » Extension-Registry as OSGi Services
Extension-Registry as OSGi Services [message #97453] Fri, 14 September 2007 11:04 Go to next message
Originally posted by: matthias.spam.de
I'm using the Extension-Registry as an OSGi-Service. Somehow I can't
import the package org.eclipse.core.runtime in my manifest.mf. Only if I
require the bundle org.eclipse.equinox.registry it works. If I try to
import the package Eclipse tells me it can't see it.
Since I want to use some OSGi-Best Practices and not depend on an
particular bundle I would like to use the Import-Package deklaration.
Any ideas?
Matt
Re: Extension-Registry as OSGi Services [message #97476 is a reply to message #97453] Fri, 14 September 2007 11:33 Go to previous messageGo to next message
Hi, Matthias
If you don't have org.eclipse.core.runtime bundle, you won't be able to
import org.eclipse.core.runtime package. Although it is exported by
org.eclipse.equinox.registry bundle, it has a mandatory attribute
attached to the export:
org.eclipse.core.runtime; registry="split"; mandatory:="registry"
If you want to import it, you need the following syntax:
Reference:
[1] OSGi Core Specification, c.3.6 Constraint Solving
Danail
Matthias wrote:
> Hi
> Any ideas?
> Matt
Re: Extension-Registry as OSGi Services [message #97491 is a reply to message #97476] Fri, 14 September 2007 16:05 Go to previous messageGo to next message
OK as far as I understand the docs:
The bundle org.eclipse.equinox.registry exports the package as follows:
Which tells me there is an mandatory attribute that any importer has to
set. This mandatory attribute is called registry and has to be set to
"split".
Wow.
@Danail THANKS.
Now this is the technical resolution. But why did the registry bundle
choose to set these attributes? And what are the consequences for me?
Matt
Danail Nachev schrieb:
> Hi, Matthias
> Reference:
> Danail
> Matthias wrote:
>> Hi
>> Any ideas?
>> Matt
Re: Extension-Registry as OSGi Services [message #97505 is a reply to message #97491] Sat, 15 September 2007 02:58 Go to previous message
The registry bundle exports org.eclipse.core.runtime package in this
special way, because it is not the only exporter of the package. The
package is so called "split package" [1] and thus, in order to get all
of the package contents, there must be a package exporter, which
consolidate all of the package parts. In order to be sure that importer
of org.eclipse.core.runtime without any attributes, all of the parts
must be added special requirements for their importing. Otherwise, it
cannot be guaranteed which package will be wired.
Danail
[1] OSGi Core Specification 4.1, c.3.13 Requiring Bundles
> "split".
> Wow.
> @Danail THANKS.
> Matt
>> Hi, Matthias
>> Reference:
>> Danail
>> Matthias wrote:
>>> Hi
>>> Any ideas?
>>> Matt
Previous Topic:Xerces vs. JRE XML parsers
Next Topic:Jetty Configuration
Current Time: Sat Jul 19 13:43:19 EDT 2025
Powered by FUDForum. Page generated in 0.03092 seconds
