Finding IType for anonymous inner class [message #962183] |
Sun, 28 October 2012 19:11  |
Hi All,
I am having a problem getting an IType for an anonymous inner class.
Given the name of an anonymous inner class how can I get the associated IType?
What I have now (which doesn't work) is something like this...
// className is something that ends with a number, like "myclass.SomeClass$1"
IType getIType4AnonymousClass(String className, IJavaProject project) {
int i= className.lastIndexOf('$');
// for now assume primaryName is NOT another anonymous class
String primaryName= primaryName.substring(0, i);
IType primaryType= project.getType(primaryName);
int occurance= Integer.parseInt(className.substring(i+1));
return primaryType.getType("", occurance);
I've tried this a million different ways, I'm stumped, any help would be appreciated.
I'm using Eclipse version 3.7 (indigo).
Thanks...
Re: Finding IType for anonymous inner class [message #963347 is a reply to message #962183] |
Mon, 29 October 2012 14:55  |
I have not found a good answer to this question in the forum or on the net so I'm posting my solution to finding an anonymous inner class.
It seems to be working, but I have not yet tested it thoroughly...
* Return an IType (Source type, not Binary) for the given class name.
* @return null if no such class can be found.
* @throws JavaModelException
public static IType findType(IJavaProject javaProject, final String className)
String primaryName= className;
int i= primaryName.lastIndexOf('$');
int occurence= 0;
if (0 < i) {
try {
occurence= Integer.parseInt(primaryName.substring(i+1));
catch (NumberFormatException x) {
* IJavaProject.findType works for top level classes and named inner
* classes, but not for anonymous inner classes
IType primaryType= javaProject.findType(primaryName);
if (!primaryType.exists())
return null;
if (occurence <= 0) // if not anonymous then we done
return primaryType;
* the following snippet never works, but according to the
* docs it should.
IType innrType= primaryType.getType("", occurence);
if (innrType != null) {
String name= primaryType.getFullyQualifiedName();
if (name.equals(className)) {
return innrType;
* If we're looking for an anonymous inner class then we need to look
* through the primary type for it.
LinkedList<IJavaElement> todo= new LinkedList<IJavaElement>();
todo.add(primaryType);
IType innerType= null;
while (!todo.isEmpty()) {
IJavaElement element= todo.removeFirst();
if (element instanceof IType) {
IType type= (IType)element;
String name= type.getFullyQualifiedName();
innerType= type;
break;
if (element instanceof IParent) {
for (IJavaElement child:((IParent)element).getChildren()) {
todo.add(child);
return innerType;
FUDForum. Page generated in 0.03175 seconds
