Home » Language IDEs » C / C++ IDE (CDT) » importing makefiles
importing makefiles [message #92751] Mon, 26 January 2004 19:04 Go to next message
Originally posted by: nobody.nowhere.anywhere
Using Eclipse 3.0M6, CDT 2.0M6 on Win2k:
Trying to learn the CDT by creating a standard C++ project,
and importing existing makefiles. The help documents say
that for a standard project I must supply the makefiles.
That's good as I already have them for g++/cygwin. But...
How do I get the project to recognize these makefiles? How
do I get the CDT to extract the targets inside the makefiles?
Haven't found anything in the docs which describe how to do
this. I'll appreciate any suggestions you can give me.
....Tom Hilinski
Re: importing makefiles [message #92799 is a reply to message #92751] Tue, 27 January 2004 10:36 Go to previous messageGo to next message
Originally posted by: tstephen.milkyway.gsfc.nasa.gov
It's fairly straightforward to get the system to recognize your make
files and build the targets in them. I use eclipse 2.1.2 with CDT 1.2
but it sould apply to the newer one as well. Here's what you need to do:
1) Open a "Make Targets" view, if you don't have one opened already. It
shows up as a tab in the same frame as the "Outline" view. If it isn't
open you can open it from Windows->Show Views->Other and then pick Make
Targets under the Make heading. This should bring up a list of all your
open Projects and their sub-directories.
2) Right click on the project or subdirectory where the makefile is
located and pick "Add Build Target". A dialog will pop up, fill in the
relevant values and click Create. This will add that make target to the
project.
3) To make the target just double click on the new make target and
you're off.
If your makefile is in the Project's root directory, then selecting
Project->Build All (ctrl-B) will either execute the default build target
or 'make all'. I not sure which it is as I don't actually use that
particular feature. Someone else would have to clarify that. (The build
environment for my project use CMT for configuration management and
building and has all the make files executed in a subdirectory instead
of the project's root directory). Of course if the default make target
is 'all' it doesn't really matter. The Project->Rebuild All option does
a 'make clean' and then 'make all' in the Project's root directory.
Hope that helps.
- Tom Stephens
Programmer/Analyst
GLAST Science Support Center
> Trying to learn the CDT by creating a standard C++ project, and
> importing existing makefiles. The help documents say that for a standard
> project I must supply the makefiles. That's good as I already have them
> How do I get the project to recognize these makefiles? How do I get the
> Haven't found anything in the docs which describe how to do this. I'll
> ...Tom Hilinski
Re: importing makefiles [message #92830 is a reply to message #92799] Tue, 27 January 2004 15:31 Go to previous message
Thomas Stephens wrote:
<snip>
Thanks very much!
....Tom
Previous Topic:C/C++ plug-in
Next Topic:monthly reminder - we have a FAQ
Current Time: Wed Oct 08 07:14:12 EDT 2025
Powered by FUDForum. Page generated in 0.03122 seconds
