Home » Language IDEs » ServerTools (WTP) » Problems after upgrading to 3.1M5a + WST1M3
Problems after upgrading to 3.1M5a + WST1M3 [message #92313] Thu, 14 April 2005 18:57 Go to next message
Originally posted by: mike.estes.comcast.net
Recently I began developing using Eclipse 3.0.2. I was initially building
simple Jave applications, applets, etc. This was in preparation for
development on a larger scale WEB project. I downloaded the bundled
3.1M5a with all the prerequisites, followed the instructions to add in the
additional jar files, updated all the loaded features as required and now
I can't even view my VE java files without getting consistent generic ("An
Error Has Occured.") error messges.
When I check the log it simply states:
"Problems occured when invoking code from plugin:
"org.eclipse.ui.workbench"."
I can't even click on the error log to investigate further without
re-invoking the error.
To top it off I'm developing on a multi-OS environment with one linux
machine being used to test the new server components needed. I've
experienced a very similar result upgrading to similar levels on the linux
platform.
At least I'm consistent... Can anyone offer any guidance or words of
wisdom (besides find a new occupation). Any help would be appreciated. ME
Re: Problems after upgrading to 3.1M5a + WST1M3 [message #93172 is a reply to message #92313] Tue, 19 April 2005 13:59 Go to previous message
Originally posted by: amywu.us.DELETEME.ibm.com
I assume you downloaded 3.1M5+prereqs+WST1M3 into a separate directory
than your Eclipse 3.0.2 directory. Are you only having problems opening
your old java files created in 3.0.2 Or are you having problems all over?
You might want to try starting small. Like just installing eclipse 3.1M5
and see if everything works okay, including opening your old java files.
If that already does not work, then you should try describing your problem
on the eclipse.platform newsgroup.
If that does work, then try installing all the prereqs + WST. After
installing, the first time you bring up wtp, you might want to pass in
-clean as an argument. If things fall apart then, post back here and
describe what happened.
-amy
Previous Topic:Dynamic web project
Next Topic:cvc-elt.1: Cannot find ...
Current Time: Fri Nov 07 10:14:31 EST 2025
Powered by FUDForum. Page generated in 0.03846 seconds
