Home » Eclipse Projects » Equinox » Shared ServletContexts in HTTPService
Shared ServletContexts in HTTPService [message #921969] Mon, 24 September 2012 11:54 Go to next message
I've noticed that when registering servlets with the HTTPService, all
registered servlets have the same ServletContext, even when they are
registered with different HTTPContexts. I'm not sure if this is correct
behavior, at least it differs from Felix [1].
I've checked the code below both in Equinox from Kepler M1 and Apache
Karaf 2.2.9 using Jetty:
HttpServlet servlet1 = new TestServlet();
HttpContext httpContext1 = httpService.createDefaultHttpContext();
httpService.registerServlet( "/foo", servlet1, null, httpContext1 );
HttpServlet servlet2 = new TestServlet();
HttpContext httpContext2 = httpService.createDefaultHttpContext();
httpService.registerServlet( "/bar", servlet2, null, httpContext2 );
System.out.println( "HttpContext: "
+ httpContext1.hashCode()
+ httpContext2.hashCode() );
System.out.println( "ServletContext: "
+ servlet1.getServletContext().hashCode()
+ servlet2.getServletContext().hashCode() );
In both environments, the HttpContext instances are different, as
expected. But while the ServletContexts differ in Karaf, they are the
same in Equinox. Both servlets also get different HttpSessions in Karaf.
This behavior allows to isolate web applications within the same OSGi
instance.
Is this difference intended or would you consider it a bug?
Ralf
[1]
http://felix.apache.org/site/apache-felix-http-service.html#ApacheFelixHTTPService-ServletContextNotes
Ralf Sternberg
Twitter: @EclipseRAP
Re: Shared ServletContexts in HTTPService [message #922696 is a reply to message #921969] Tue, 25 September 2012 04:37 Go to previous messageGo to next message
Hi Ralf,
Am 24.09.2012 17:54, schrieb Ralf Sternberg:
> instance.
I read the OSGi specification as not being very strict about it. Here is
the relevant paragraph:
"[The ServletContext] is created by the implementation of the Http
Service for each unique HttpContext object with which a Servlet object
is registered. Thus, Servlet objects registered with the same
HttpContext object must also share the same ServletContext object."
It looks like the only hard requirement is to use the same
ServletContext for the same HttpContext objects but that's it. Although
the PAX Web behavior seems intuitive and I can see in the source code
how they create new contexts in Jetty for each HttpContext, I'd say it's
an implementation detail in PAX Web.
BTW, the OSGi Http Service spec doesn't mention the word "session" at
all. That's why I don't use the HttpService concept in a
multi-application environment.
I wonder if a feature request should be opened. It's an interesting idea
to support multiple applications with the same HttpService. However, I
don't see it easily supported using the current generic HttpService
implementation in Equinox. It's based on a Servlet itself and shared
between ServletBridge and Jetty.
-Gunnar
Gunnar Wagenknecht
gunnar@xxxxxxxx
http://wagenknecht.org/
Re: Shared ServletContexts in HTTPService [message #923243 is a reply to message #922696] Tue, 25 September 2012 14:47 Go to previous messageGo to next message
Thanks for your insights, Gunnar.
Yes, the spec is not very clear about this detail, so the current
behavior can probably not be considered a bug. On the other hand, having
separate "web applications" in one OSGi instance seems like the idea
behind the design and I was surprised to find that it is not implemented
this way in Equinox.
I agree that the PAX Web behavior is more intuitive, and also more
useful, and it would be great to have a similar behavior in Equinox.
I've opened an an enhancement request for it [1].
Regards, Ralf
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=390381
Ralf Sternberg
Re: Shared ServletContexts in HTTPService [message #925003 is a reply to message #923243] Thu, 27 September 2012 05:55 Go to previous message
Am 25.09.2012 20:47, schrieb Ralf Sternberg:
FYI, I pushed a modified Equinox HttpService:
https://github.com/eclipseguru/rt.equinox.bundles/tree/gunnar/bug390381
You can try by cloning the repo and importing bundle
"org.eclipse.equinox.http.servlet" into your workspace.
-Gunnar
Gunnar Wagenknecht
gunnar@xxxxxxxx
Previous Topic:Adding reference to other repostiories from p2.inf
Next Topic:Static content files outside bundle
Current Time: Sat Jul 19 15:57:23 EDT 2025
Powered by FUDForum. Page generated in 0.05084 seconds
