Home » Modeling » TMF (Xtext) » Odd double clicking ?
Odd double clicking ? [message #908629] Wed, 05 September 2012 13:19 Go to next message
I have noticed odd behaviour when double clicking to select text.
Somethimes only a single letter, sometimes two are selected, and
sometimes the entire word is correctly selected.
It seems related to where in the "word" the pointer is when double
clicking - if towards the beginning or end, it does the right thing, but
if in the middle it seems to prefer selecting a single or two characters.
My question is if Xtext is involved in this at all, and if so, any hints
where I should look for where this happens. I Can imagine that it
relates to what is being clicked on, and find the significant portion to
select.
- henrik
Re: Odd double clicking ? [message #908905 is a reply to message #908629] Thu, 06 September 2012 03:57 Go to previous messageGo to next message
Yes, Xtext handles this according to the lexer tokens with some special
semantics for ML comments and Strings.
See org.eclipse.xtext.ui.editor.doubleClicking.DoubleClickStrategyProvider
and
org.eclipse.xtext.ui.editor.doubleClicking.LexerTokenAndCharacterPairAwareStrategy
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 05.09.12 19:19, schrieb Henrik Lindberg:
> select.
> Regards
> - henrik
Re: Odd double clicking ? [message #908997 is a reply to message #908905] Thu, 06 September 2012 07:24 Go to previous messageGo to next message
> and
I debugged this, and found that DocumentParitioner is basing its
decision on faulty information.
Clicking at the position marked | in the string 'a|bcd', returns a
partition consisting of abcd only. It returns a region based on that.
The end result is a selection if bc only.
If I double click (marked |) 'ab|cd', I also get a region consisting of
abcd, but now I get the correct selection; all of abcd.
So - mapping to typed region seems ok.
In
o.e.xtext.ui.editor.doubleClicking.AbstractPartitionDoubleClickSelector.findExtendedDoubleClickSelection(IDocument,
int offset) however, it does this:
if (offset == region.getOffset() + 1
|| offset == region.getOffset() + region.getLength() - 1) {
return getSelectedRegion(document, region);
otherwise, it returns null. This is called for the
FixedCharCountPartitionDoubleClickSelector configured for the STRING
partition. (It in turn has margins of 1 assigned).
This seems to be the logic for "select the entire string if at one of
the ends", because if it returns null, the logic above continues with a
search for a Word match.
Everything would be ok, if the underlying region had included the
quotes. I do have a specialized implementation of
TokenTypeToStringMapper that includes these rules:
if("RULE_WORD_CHARS".equals(tokenName))
return STRING_LITERAL_PARTITION;
if("RULE_ANY_OTHER".equals(tokenName))
if("'::'".equals(tokenName))
if("'$'".equals(tokenName))
// issue #276, screws up bracket matching
// if("'${'".equals(tokenName))
// return STRING_LITERAL_PARTITION;
if("'\\''".equals(tokenName))
if("'\\\"'".equals(tokenName))
if("'\\$'".equals(tokenName))
if("'\\${'".equals(tokenName))
if("'\\\\".equals(tokenName))
if("'\''".equals(tokenName))
if("'\"'".equals(tokenName))
I have this binding:
public Class<? extends ITokenTypeToPartitionTypeMapper>
bindITokenTypeToPartitionTypeMapper() {
return PPTokenTypeToPartionMapper.class;
And I can see it gets called.
Is there another token to partition mapper involved?
- henrik
Re: Odd double clicking ? [message #909050 is a reply to message #908997] Thu, 06 September 2012 09:06 Go to previous message
Thanks to Sebastian Zarnekow, I now know that I needed to bind a
PartitionTokenScanner that does this:
protected boolean shouldMergePartitions(String contentType) {
return super.shouldMergePartitions(contentType) ||
PPTokenTypeToPartionMapper.STRING_LITERAL_PARTITION.equals(contentType);
Since it did not expect strings to be implemented with multiple tokens.
Now it works!
- henrik
>> See
>> and
> In
> Regards
> - henrik
Previous Topic:Inject issue with Eclipse Juno
Next Topic:Accessing the resource set from other plugin
Current Time: Sun Jul 20 10:44:13 EDT 2025
Powered by FUDForum. Page generated in 0.04189 seconds
