Home » Archived » EGL Development Tools » Errors in org.eclipse projects after nightly build update
Errors in org.eclipse projects after nightly build update [message #898358] Thu, 26 July 2012 05:20 Go to next message
Using EDT version 0.8.0. Been following the milestones and nightly builds for a while now. I ran a software update this morning and moved to 0.8.1.v201207252109 and I've now got 93 errors in the following projects:
org.eclipse.edt.rui.dojo.remote_0.8.1
org.eclipse.edt.rui.widgets_0.8.1
I've attached a file detailing the errors.
Steve
Re: Errors in org.eclipse projects after nightly build update [message #898489 is a reply to message #898358] Thu, 26 July 2012 09:22 Go to previous messageGo to next message
Steve,
Thanks for heads up on this issue. I have opened a high severity defect in bugzilla - https: //bugs.eclipse.org/bugs/show_bug.cgi?id=386041
We recently finished working on the EDT .8.1 release, and have now started building EDT version .8.2 (although the version numbers haven't been updated yet). It looks like a breaking change was checked in that is causing the 'class' property of a Widget to appear as a reserved word.
At this point in time, due to the fact that our final .8.1 build has not yet been published, I would recommend that you uninstall your latest build and install the .8.1 milestone 3 build. The .8.1 release build should be published soon, and you can can migrate to that build for any additional fixes that were made after the milestone 3 build was published. In the future, to avoid running into issues like this, I would recommend using milestone builds instead of nightly builds.
-Brian
Re: Errors in org.eclipse projects after nightly build update [message #898501 is a reply to message #898489] Thu, 26 July 2012 09:43 Go to previous message
I'll update the version numbers in tonight's build, except for the _0.8.1 suffix on the widget projects.
-Matt
Previous Topic:EGL Environment issues
Next Topic:Where are the EDT roadmaps?
Current Time: Sun Jul 27 22:20:46 EDT 2025
Powered by FUDForum. Page generated in 0.05895 seconds
