| branch deletion broken in Juno? [message #893992] |
Fri, 06 July 2012 07:05  |
I just switched to Juno + egit nightlies and branch deletion seems to fail consistently:
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommandInContext(LegacyHandlerService.java:544)
at org.eclipse.egit.ui.internal.CommonUtils.runCommand(CommonUtils.java:119)
at org.eclipse.egit.ui.internal.dialogs.CheckoutDialog$3.widgetSelected(CheckoutDialog.java:205)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4134)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1458)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1481)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1466)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1271)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3980)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3619)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.egit.ui.internal.branch.BranchOperationUI.getTargetWithDialog(BranchOperationUI.java:288)
at org.eclipse.egit.ui.internal.branch.BranchOperationUI.start(BranchOperationUI.java:152)
at org.eclipse.egit.ui.internal.actions.SwitchToMenu$2.widgetSelected(SwitchToMenu.java:187)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.egit.ui.internal.repository.tree.command.RemoveCommand.removeRepository(RemoveCommand.java:78)
at org.eclipse.egit.ui.internal.repository.tree.command.DeleteCommand.execute(DeleteCommand.java:22)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 51 more
OS X 10.7.4
Version: Juno Release
Build id: 20120614-1722
Eclipse EGit 2.1.0.201207041114
FUDForum. Page generated in 0.05439 seconds
