Home » Modeling » MoDisco » Looking for a tutorial
Looking for a tutorial [message #892627] Thu, 28 June 2012 15:30 Go to next message
Is there a good tutorial how I can use MoDisco when I don't know much about the tool?
Specifically, I'm looking for ways to check design constraints in my source code. An example could be that Locale.getDefault() must not be called anywhere - directly or indirectly.
Or how would I go about converting FindBugs/PMD rules to MoDisco?
Is it possible to analyze the source code with MoDisco and write unit tests that check such constraints?
Re: Looking for a tutorial [message #892685 is a reply to message #892627] Fri, 29 June 2012 04:12 Go to previous message
You can find many presentations on MoDisco and a complete demo from: http://wiki.eclipse.org/MoDisco#Screencasts_.26_Slides
This should help you understand the capabilities of the framework.
Also, I recommend you to take a look to the MoDisco reference documentation (http://download.eclipse.org/modeling/mdt/modisco/nightly/doc/org.eclipse.modisco.doc/) to have a full view of the various provided components.
Generally, MoDisco will help you to obtain exploitable models out of your source code and provide you facilities to handle them more efficiently.
Then, you can use model transformation (http://www.eclipse.org/atl/) to navigate through your models and generate accordingly a new code model representing the unit tests to be produced.
Hugo
Previous Topic:no uml file from kdm
Next Topic:PHP discoverer
Current Time: Sun Jul 27 11:26:19 EDT 2025
Powered by FUDForum. Page generated in 0.03434 seconds
