Home » Archived » M2M (model-to-model transformation) » I have downloaded the QVT to ATL Virtual Machine Compiler
I have downloaded the QVT to ATL Virtual Machine Compiler [message #87411] Tue, 05 August 2008 06:20 Go to next message
from the http://www.eclipse.org/m2m/atl/atlTransformations/#QVT2ATLVM
I am using the Eclipse Ganyemede Version: 3.4.0.
When I run this application,I get the following error:Any helps in this
direction please.
SEVERE: cannot find model QVT
java.lang.RuntimeException: cannot find model QVT
at
org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDeb ugger.java:195)
at
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:95)
at
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:91)
at
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:292)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:171)
at
org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:299)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:169)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:111)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:87)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:326)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:426)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:398)
at
org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:42)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:764)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:614)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:880)
at
org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1083)
Swetha.
Re: I have downloaded the QVT to ATL Virtual Machine Compiler [message #88144 is a reply to message #87411] Mon, 11 August 2008 20:26 Go to previous message
Hi Sweta,
You have to make sure the QVT metamodel is registered. You could do this by
installing org.eclipse.am3.ui and dependencies. It will give you the
opportunity to register a metamodel in eclipse by rightclicking on it.
Alfons
"Swetha" <swetha.tarachandra@continental-corporation.com> schreef in bericht
news:9fcc35c2fb3c285bfe4f2002e51a115d$1@www.eclipse.org...
> Hello,
> direction please.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Regards,
> Swetha.
Previous Topic:[QVTO] Unit testing
Next Topic:[ATL] How to use UML Primitive Types
Current Time: Sat Jul 19 21:12:15 EDT 2025
Powered by FUDForum. Page generated in 0.03794 seconds
