Home » Archived » EGL Development Tools » javascriptDev(linked handler from other project do not update)
javascriptDev [message #879481] Thu, 31 May 2012 05:49 Go to next message
I have two projects in the workspace and project2 linkes a handler from project1. This is working fine, but when I changed the handler in project1, the change do not reflect in project2. I have tried to clean, remove the reference to the handler and re-insert the reference. After some digging I found that the handler with the old layout is located in javascriptDev that is hidden from ProjectExplorer. If I remove the handler from this folder I get errors when opening the project.
Is there a way to force regenerate of the content in javascriptDev?
I am currently using 0.8.0.v201204061050
Rgds Trond
[Updated on: Thu, 31 May 2012 05:51] by Moderator
Re: javascriptDev [message #879756 is a reply to message #879481] Thu, 31 May 2012 15:39 Go to previous messageGo to next message
Hi Trond,
To force regeneration of javascriptDev, run a Project > Clean. This folder is hidden because we don't want you deleting it, it's needed by the IDE for the visual editor and debugger (the generated files contain a lot of extra code used by these features that you don't want in your deployed application).
As for your root problem, let's call them handlers "A" and "B", where "B" is using "A". When you changed "A", did you refresh "B"? I think that the visual editor will only automatically update the display when you modify the file being viewed, and if you modify dependent files (like another handler it uses) you will have to click the refresh button.
-Justin
Re: javascriptDev [message #879968 is a reply to message #879756] Fri, 01 June 2012 04:02 Go to previous messageGo to next message
Thanks for you suggestions Justin. I tried, but unfortunatly it did not work. However, I renamed "A" and then it was shown correctly in "B". Then I renamed "A" back to the originally name and old version was back (in "B"), but when I again renamed "A" and changed it, the change was reflected also in "B". Conclusion is, I think, that now it workes as it should. Something has "locked up" with original "A", but as it workes as it should with renamed "A", problem is solved Smile
/Trond
Re: javascriptDev [message #882030 is a reply to message #879968] Tue, 05 June 2012 12:53 Go to previous message
While I'd still like to find what went wrong in the first place, I'm glad it's working for you now.
-Justin
Previous Topic:Continue getting "Can't find bundle for base name ..., locale en_US" problem
Next Topic:Error in function addDays? (only javascript)
Current Time: Sat Jul 26 07:46:12 EDT 2025
Powered by FUDForum. Page generated in 0.09646 seconds
