Home » Eclipse Projects » Remote Application Platform (RAP) » Tree really slow in IE7
Tree really slow in IE7 [message #86991] Tue, 13 May 2008 12:08 Go to next message
Hi all,
I tried to implement a tree with 5 coulumns. It has roughly 100 root
elements and each of it has ~5 subelements. Since in most cases the tree
needs to be expanded completely I didn´t use a content provider.
In firefox this works quite fine, but in IE7 the memory starts to explode
and the timout gets hit, asking if I want to kill the javascript.
To test if I really didn´t had something else slowing down I reduced the
core to this:
private void refreshTable() {
tree.removeAll();
for (int i=0; i<100; i++) {
TreeItem tiParent = new TreeItem(tree, SWT.NONE);
tiParent.setText("ParentItem Number "+i+" All Right!!");
for (int j=0;j<5;j++) {
TreeItem ti = new TreeItem(tiParent, SWT.NONE);
ti.setText(new String[]{"Child Item number "+j, "Propertiy 1",
"Property 2", "Property 3", "Property 4"});
It still hits the timeout (on a X2 6000+ 4GB RAM system!)
Since I can´t influence the used Browser (in a corporation) this means
really trouble for my code.
Any help?
Greetings,
Torge.
Re: Tree really slow in IE7 [message #87021 is a reply to message #86991] Tue, 13 May 2008 15:48 Go to previous messageGo to next message
Originally posted by: evolanakis.innoopract.com
--------------050000030909010702010604
Hi Torge,
the code you posted disposes and recreates every tree item in the tree.
This is quite an expensive operation since a big part of the work
happens on the browser side. In my experiments (see attached example),
letting a TreeViewer manage the TreeItems was more efficient.
Hope this helps.
Kind regards,
Elias.
Elias Volanakis
Innoopract, Inc.
http://www.innoopract.com
Torge Kummerow wrote:
> Hi all,
Re: Tree really slow in IE7 [message #87212 is a reply to message #87021] Wed, 14 May 2008 10:08 Go to previous messageGo to next message
Well, thanks for the fast reply. I will try it, even though it means a lot
of rewriting for my code.
I Hope it will help. Even though I doubt it. It will be faster in
representing the root elements for sure. But will it be any faster if I
expand all nodes?
I will let you know the result.
Greetings,
Torge.
"Elias Volanakis" <evolanakis@innoopract.com> schrieb im Newsbeitrag
news:g0cram$slh$1@build.eclipse.org...
> Hi Torge,
> Hope this helps.
> Kind regards,
> Elias.
> Elias Volanakis
> Innoopract, Inc.
>> Hi all,
>> explode and the timout gets hit, asking if I want to kill the javascript.
>> core to this:
>> tree.removeAll();
>> Any help?
>> Greetings,
>> Torge.
> * Copyright (c) 2008 Innoopract Informationssysteme GmbH.
> * All rights reserved. This program and the accompanying materials
> * are made available under the terms of the Eclipse Public License v1.0
> * which accompanies this distribution, and is available at
> * http://www.eclipse.org/legal/epl-v10.html
> * Contributors:
> * Innoopract Informationssysteme GmbH - initial API and implementation
> package rap.example2;
> import java.util.ArrayList;
> import java.util.List;
> import org.eclipse.jface.dialogs.MessageDialog;
> import org.eclipse.jface.viewers.ITreeContentProvider;
> import org.eclipse.jface.viewers.LabelProvider;
> import org.eclipse.jface.viewers.TreeViewer;
> import org.eclipse.jface.viewers.Viewer;
> import org.eclipse.swt.SWT;
> import org.eclipse.swt.events.SelectionAdapter;
> import org.eclipse.swt.events.SelectionEvent;
> import org.eclipse.swt.layout.FillLayout;
> import org.eclipse.swt.widgets.Button;
> import org.eclipse.swt.widgets.Composite;
> import org.eclipse.swt.widgets.Tree;
> import org.eclipse.ui.part.ViewPart;
> public class View extends ViewPart {
> public static final String ID = "rap.example2.view";
> * This is a callback that will allow us to create the viewer and
> initialize
> * it.
> public void createPartControl(Composite parent) {
> final Tree tree = new Tree(parent, SWT.MULTI | SWT.BORDER);
> parent.setLayout(new FillLayout());
> final TreeViewer viewer = new TreeViewer(tree);
> viewer.setLabelProvider( new LabelProvider() );
> viewer.setContentProvider( new NodeContentProvider() );
> viewer.setInput( new Object[0] );
> Button b = new Button( parent, SWT.PUSH );
> b.setText("Refresh");
> b.addSelectionListener( new SelectionAdapter() {
> @Override
> public void widgetSelected( SelectionEvent e ) {
> long now = System.currentTimeMillis();
> // tree.setRedraw( false ); // this only makes sense in RCP
> viewer.setInput( createInput() );
> // tree.setRedraw( true ); // this only makes sense in RCP
> MessageDialog.openInformation( tree.getShell(), "huhu", "done");
> System.err.println("Approx. ELAPSED: " +
> (System.currentTimeMillis() - now));
> Button b2 = new Button( parent, SWT.PUSH );
> b2.setText( "Expand All" );
> b2.addSelectionListener( new SelectionAdapter() {
> @Override
> viewer.expandAll();
> public void setFocus() {
> // helping methods
> private long iCount = 0;
> private Object[] createInput() {
> List<Object> nodes = new ArrayList<Object>();
> Node node = new Node("ParentItem Number "+iCount+" All Right!!");
> iCount++;
> Node child = new Node("Child Item number "+j);
> node.addChild( child );
> nodes.add( node );
> return nodes.toArray();
> // helping classes
> private static class NodeContentProvider implements ITreeContentProvider
> public Object[] getChildren( Object parentElement ) {
> return ((Node) parentElement).getChildren();
> public Object getParent( Object element ) {
> // unused
> return null;
> public boolean hasChildren( Object element ) {
> return ((Node)element).hasChildren();
> public Object[] getElements( Object inputElement ) {
> return ( Object[] )inputElement;
> public void dispose() {
> // unused
> public void inputChanged( Viewer viewer, Object oldInput, Object
> newInput )
> // unused
> private static class Node {
> private String text;
> private List<Node> children;
> Node(String text) {
> this.text = text;
> void addChild(Node node) {
> if(children == null) {
> children = new ArrayList<Node>();
> children.add(node);
> Node[] getChildren() {
> return new Node[0];
> return children.toArray(new Node[children.size()]);
> boolean hasChildren() {
> return children == null ? false : !children.isEmpty();
> public String toString() {
> return text;
Re: Tree really slow in IE7 [message #87324 is a reply to message #87212] Wed, 14 May 2008 12:57 Go to previous message
Torge,
your 've got a good point: Adding a viewer.expandAll() after the
viewer.setInput(...) in my example will slow it down to about 20s and I
get the "JavaScript takes too long" dialog.
I'll experiment a bit further...
Elias.
> lot of rewriting for my code.
> expand all nodes?
> Greetings,
> Torge.
>> Hi Torge,
>> Hope this helps.
>> Kind regards,
>> Elias.
>> Elias Volanakis
>> Innoopract, Inc.
>>> Hi all,
>>> javascript.
>>> core to this:
>>> tree.removeAll();
>>> Any help?
>>> Greetings,
>>> Torge.
>> * Contributors:
>> implementation
>> initialize
>> * it.
>> @Override
>> @Override
>> viewer.expandAll();
>> // helping methods
>> iCount++;
>> nodes.add( node );
>> // helping classes
>> ITreeContentProvider {
>> // unused
>> return null;
>> // unused
>> newInput )
>> // unused
>> Node(String text) {
>> this.text = text;
>> children.add(node);
>> return new Node[0];
>> return text;
Elias Volanakis
Innoopract, Inc.
Previous Topic:Image
Next Topic:can I handle cursor keys?
Current Time: Mon Oct 27 21:58:39 EDT 2025
Powered by FUDForum. Page generated in 0.09469 seconds
