Home » Eclipse Projects » Virgo » How to view bundle dependency graph on Virgo
How to view bundle dependency graph on Virgo [message #871634] Mon, 14 May 2012 11:30 Go to next message
Greetings,
This is a simple question but I can't find an answer, where to put jmx jar in order to be able to view the bundle dependency graph, I'm following this this article[wiki .eclipse.org/Libra/User_Guide#Adding_OSGi_JMX_Provider] wich states :
"Download the jmx-1.0.2 bundle or a newer version.
Save the bundle in a separate directory on the local filesystem.
Open the server editor (by double-clicking on the server node in the Servers view).
Switch to the Target Platform Profile editor part.
Add the directory with the downloaded bundle to the target platform.
Save the editor."
But in Virgo I can't find "Target Platform Profile editor ", I tried to copy the jar to VIRGO_HOME/repository/usr
but that didn't work,
My setup is :
VTS 3.5M04
The latest Virgo eclipse tooling
MAC OS X SL (tried on Win 7 too)
Thank you for your time.
Re: How to view bundle dependency graph on Virgo [message #871663 is a reply to message #871634] Mon, 14 May 2012 12:42 Go to previous messageGo to next message
You shouldn't need to do any of that. The graph is there by default but it has been broken because of issues with the Libra code - these are two different projects but coming from the same original code base. Those have been fixed but need to go through IP process to end up in Libra build. See: 350914: Bundle dependency graph displays a blank screen
https://bugs.eclipse.org/bugs/show_bug.cgi?id=350914
cheers,
Miles
Re: How to view bundle dependency graph on Virgo [message #871666 is a reply to message #871663] Mon, 14 May 2012 12:48 Go to previous messageGo to next message
Actually, I just checked and it should already be there. However, that means that you'll need to install Libra from their snapshot page if you want to try the fix. That's at:
http://download.eclipse.org/libra/nightly
Re: How to view bundle dependency graph on Virgo [message #871964 is a reply to message #871666] Tue, 15 May 2012 04:19 Go to previous message
Thank you Parker, installing from the libra repo worked like a charm,
Greetings .
Previous Topic:Greenpages 2.4 not working
Next Topic:Spring OSGI version in virgo 3.5.0.M4
Current Time: Wed Jul 23 10:52:12 EDT 2025
Powered by FUDForum. Page generated in 0.09576 seconds
