Home » Modeling » TMF (Xtext) » Nested EPackage in ECore model cannot be imported in XText
Nested EPackage in ECore model cannot be imported in XText [message #869356] Thu, 03 May 2012 05:26 Go to next message
I'm trying to define a grammar based on several ECore models.
Those models contains nested packages :
 - platform:/resource/model.ecore
    - rootPack
       - some EClasses
       - subPack
          - some Classes
If I'm trying to import thoses models using this way :
import 'platform:/resource/model.ecore'
In my XText grammar, I cannot acces the classes located in the sub Package, only the classes which are defined in the root package are available.
The only way I managed to work this out, is to install my models (and generated plugins) in the workbench and reference the package using their NS_URI.
import 'www.url.org/rootPack'
import 'www.url.org/rootPack/subPack' as subPack
But this way I have classpath issues. And moreover, this is not acceptable beacause I would like to be able to work on my models in the same workspace in which the Xtext project is located.
Any advice on how to accheive that ?
Kind regards,
Charles
Re: Nested EPackage in ECore model cannot be imported in XText [message #869623 is a reply to message #869356] Thu, 03 May 2012 14:07 Go to previous messageGo to next message
in general the use of nested epackages is discouraged. same is for the
use of platform:/resource uris - they are deprecated. never the less
something like the folloing should work: import
"platform:/resource/org.xtext.example.mydsl/src/org/xtext/example/mydsl/My.ecore#//subpackage"
~Christian
Re: Nested EPackage in ECore model cannot be imported in XText [message #870188 is a reply to message #869623] Mon, 07 May 2012 04:14 Go to previous message
Thank you very much, your answer was very usefull.
I will take your advice into account, but I don't have the ownership of the metamodel.
Charles Bonneau
Previous Topic:some newbie questions...
Next Topic:Copying folders
Current Time: Sat Jul 19 10:02:17 EDT 2025
Powered by FUDForum. Page generated in 0.04202 seconds
