Home » Archived » M2M (model-to-model transformation) » [ATL] Ecore model and Jet Template
[ATL] Ecore model and Jet Template [message #86947] Wed, 23 July 2008 15:29 Go to next message
Originally posted by: irbull.cs.uvic.ca
Hi all,
We have a mapping tool and we are hoping to use it to generate an ATL
mapping. Does anyone know if there is an ATL Metamodel (in Ecore) and /
or a Jet template that we could use to generate the ATL program from an
instance of this metamodel?
Ian
Re: [ATL] Ecore model and Jet Template [message #87023 is a reply to message #86947] Thu, 24 July 2008 07:06 Go to previous messageGo to next message
Yes, there is an ATL metamodel. When you launch an ATL transformation
written in the ATL concrete syntax, it is then injected into an ATL
model conformed to the ATL metamodel. This also means that you can
create a ATL transformation model from another ATL transformation.
The metamodel is here :
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.atl/plugins/org.eclipse.m2m.atl.engine/src/org/ecli pse/m2m/atl/engine/resources/ATL-0.2.ecore?root=Modeling_Pro ject&view=log
To extract an ATL model to its concrete syntax (the ATL program) and to
inject an ATL program into a ATL model, a TCS injector and extractor are
used. TCS is a tool used to bridge the grammar technical space (programs
defined by a grammar) and the model technical space (models conformed to
a metamodel).
Installing the AM3 plugin will let you inject and extract ATL
transformation from the eclipse UI.
http://www.eclipse.org/gmt/am3/download/
Ian Bull wrote :
> Hi all,
> Ian
Re: [ATL] Ecore model and Jet Template [message #87100 is a reply to message #87023] Thu, 24 July 2008 13:26 Go to previous message
Thank-you so much!
I have been very excited about the TCS project, but this is my first
chance to use it.
BTW, I grabbed the ATL-0.2.ecore file, and there are a few problems. The
primitive types don't have instance names associated with them. (so you
can't create the genmodel from it).
Once I added these types, it worked fine.
Do you want me to open a bug about this?
Thanks again,
- Ian
> a metamodel).
> Ian Bull wrote :
>> Hi all,
>> / or a Jet template that we could use to generate the ATL program from
>> an instance of this metamodel?
>> Thanks,
>> Ian
Previous Topic:[ATL] Open Run Dialog
Next Topic:[ATL] Problem with the Eclipse BPEL ecore Metamodel
Current Time: Thu Oct 09 17:57:37 EDT 2025
Powered by FUDForum. Page generated in 0.03644 seconds
