Home » Eclipse Projects » Virgo » Fail to load bundle from repository
Fail to load bundle from repository [message #857629] Thu, 26 April 2012 14:20 Go to next message
Hi.
I was just wondering if there was something special to do to deploy bundle on Virgo start ?
Currently I'm using repository/usr/ to store my bundle (as the examples from the wiki). But for an unknown reason bundle are not deployed when Virgo is started. It's a fresh install of Virgo.
I'm on windows 7 using a jdk6 x64.
Thanks.
Edit: I forgot to mention that the bundles deploy correctly when uploading them via the web interface.
[Updated on: Thu, 26 April 2012 14:36] by Moderator
Re: Fail to load bundle from repository [message #857647 is a reply to message #857629] Thu, 26 April 2012 14:43 Go to previous messageGo to next message
Mastah,
Take a look at these two references.
http://www.eclipse.org/virgo/documentation/virgo-documentation-3.5.0.M03/docs/virgo-user-guide/html/ch12.html#deployment-deploying
http://www.eclipse.org/virgo/documentation/virgo-documentation-3.0.0.x/docs/virgo-user-guide/html/ch08.html
Then look at the console to get a better sense for what is going on:
You can use Virgo tooling for the console or cmd-line:
http://www.eclipse.org/virgo/documentation/virgo-documentation-3.0.0.x/docs/virgo-user-guide/htmlsingle/virgo-user-guide.html#admin-shell-vsh-command-reference
hth,
Miles
Re: Fail to load bundle from repository [message #857731 is a reply to message #857647] Thu, 26 April 2012 16:18 Go to previous messageGo to next message
Already doing all that, but the console or log doesn't give me any log entry about loading the bundles or failing with a stack.
Re: Fail to load bundle from repository [message #861724 is a reply to message #857629] Sat, 28 April 2012 14:05 Go to previous message
Ok, I got it working.
I though the bundle were starting automatically on start up, but I was wrong. They are just starting when the said bundle requesting the exported package ask for them.
That's very smart. It avoid conflict and such like that.
Previous Topic:Virgo 3.0.3.RELEASE
Next Topic:Disable Automatic Fragment Resolution
Current Time: Sat Jul 26 02:23:02 EDT 2025
Powered by FUDForum. Page generated in 0.06788 seconds
