Splash Screen with Progress Bar and Messages [message #843741] |
Fri, 13 April 2012 06:21  |
Hello
I would like to have a Splash Screen with Progress Bar and loading Messages in my pure e4 Application. The splash.bmp is displayed as documented.
To get the progress bar and the messages I tried to things:
1) I actived "Add a progress bar" and "Add a progress message" in the "Splash" tab of the product configuration. This has no effect in itself (except for the new properties in plugin.xml). Is there an API I can use to get the progress bar and the message area for further configuration?
2) I tried to use one of the templates. This creates an extension in the plugin.xml which points to a new class derived from AbstractSplashHandler. Since the AbstractSplashHandler is part of org.eclipse.ui.workspace I don't have this class available. It is a simple task to extract this class, but even then I get a compile error: "Unknown extension point: 'org.eclipse.ui.splashHandlers'. I conclude that this approach will only work by pulling in the compat-layer.
Is there another possible solution?
Greetings
Christoph
Re: Splash Screen with Progress Bar and Messages [message #857153 is a reply to message #843741] |
Thu, 26 April 2012 05:35   |
I have been asked to share my solution, so here it is. There is still work to be done though ... i.e. I haven't included a progress bar yet.
1) Interface of the Service
public interface ISplashService {
* Tell the Service where to find the Splash-Image
* @param pluginId ID of teh Plugin where the Image resides
public void setSplashPluginId(String pluginId);
* Tell the service the path and name of the Splash-Image
* @param path Path and filename of the Spalsh-Image
public void setSplashImagePath(String path);
* Open the Splash-Screen
public void open();
* Colse the Splash Screen
public void close();
* Set the displayed message on the Splash-Screen
* @param message Text-Message to be displayed.
public void setMessage(String message);
2) Register the Service with OSGi (as declarativ service):
<scr:component xmlns:scr="http://www.osgi.org/xmlns/scr/v1.1.0" name="de.emsw.ui.splash">
<implementation class="de.emsw.ui.splash.internal.SplashServiceImpl"/>
<service>
<provide interface="de.emsw.ui.splash.ISplashService"/>
</service>
</scr:component>
3) Using the Service in the LifeCycleManager
@PostContextCreate
void postContextCreate(final ISplashService splashService, final IEventBroker eventBroker) {
splashService.setSplashPluginId(YOUR_PLUGIN_ID);
splashService.setSplashImagePath(YOUR_PLUGIN_PATH);
splashService.open();
splashService.setMessage("Starting Applikation ...");
// The should be a better way to close the Splash
// see https://bugs.eclipse.org/bugs/show_bug.cgi?id=376821
eventBroker.subscribe(UIEvents.UILifeCycle.ACTIVATE, new EventHandler() {
public void handleEvent(Event event) {
splashService.close();
eventBroker.unsubscribe(this);
4) Updating the Message (by Example)
public class SomePart {
@PostConstruct
void postConstruct(ISplashService splashService) {
splash.setMessage("Loading Something ...");
5) The Service Implementation
public class SplashServiceImpl implements ISplashService {
private String pluginId = null;
private String splashPath = "splash.bmp";
private Shell splashShell = null;
private Label textLabel = null;
private String nextMessage = null;
public void setSplashPluginId(String pluginId) {
Assert.isLegal(pluginId != null && !pluginId.equals(""));
this.pluginId = pluginId;
public void setSplashImagePath(String splashPath) {
Assert.isLegal(splashPath != null && !splashPath.equals(""));
this.splashPath = splashPath;
public void open() {
if (pluginId == null)
throw new IllegalStateException("The SplashPluginId has not been set.");
if (splashPath == null)
throw new IllegalStateException("The SplashImagePath has not been set.");
logger.info("Showing Splash Screen ...");
splashShell = createSplashShell();
splashShell.open();
private Shell createSplashShell() {
final Shell shell = new Shell(SWT.TOOL | SWT.NO_TRIM);
Image image = createBackgroundImage(shell);
shell.setBackgroundImage(image);
shell.setBackgroundMode(SWT.INHERIT_DEFAULT);
final GridLayout layout = new GridLayout();
layout.numColumns = 1;
layout.marginHeight = 40;
layout.marginWidth = 20;
layout.verticalSpacing = 6;
layout.horizontalSpacing = 6;
shell.setLayout(layout);
// TODO Set the postion and stlye of the text from outside to make the service reusable
textLabel = createTextLabel(shell);
Rectangle imageBounds = image.getBounds();
shell.setSize(imageBounds.width, imageBounds.height);
shell.setLocation(getMonitorCenter(shell));
return shell;
private Image createBackgroundImage(Shell parent) {
final Image splashImage = getImageDescriptor(pluginId, splashPath).createImage();
parent.addDisposeListener(new DisposeListener() {
public void widgetDisposed(DisposeEvent e) {
splashImage.dispose();
return splashImage;
private ImageDescriptor getImageDescriptor(String pluginId, String path) {
try {
if (!path.startsWith("/")) {
path = "/" + path;
URL url = new URL("platform:/plugin/" + pluginId + path);
url = FileLocator.resolve(url);
return ImageDescriptor.createFromURL(url);
} catch (MalformedURLException e) {
String msg = NLS.bind("The image path {0} in not a valid location the bundle {1}.", path, pluginId);
throw new RuntimeException(msg, e);
} catch (IOException e) {
String msg = NLS.bind("The image {0} was not found in the bundle {1}.", path, pluginId);
private Label createTextLabel(Composite parent) {
Label label = new Label(parent, SWT.WRAP);
GridData gd = new GridData();
gd.horizontalAlignment = SWT.FILL;
gd.verticalAlignment = SWT.BOTTOM;
gd.grabExcessHorizontalSpace = true;
gd.grabExcessVerticalSpace = true;
label.setLayoutData(gd);
label.setForeground(parent.getDisplay().getSystemColor(SWT.COLOR_WHITE));
label.setFont(parent.getDisplay().getSystemFont());
if (nextMessage != null) {
label.setText(nextMessage);
return label;
private Point getMonitorCenter(Shell shell) {
Monitor primary = shell.getDisplay().getPrimaryMonitor ();
Rectangle bounds = primary.getBounds();
Rectangle rect = shell.getBounds();
int x = bounds.x + (bounds.width - rect.width) / 2;
int y = bounds.y + (bounds.height - rect.height) / 2;
return new Point(x, y);
public void close() {
splashShell.close();
splashShell = null;
public void setMessage(final String message) {
if (textLabel != null && !textLabel.isDisposed()) {
splashShell.getDisplay().syncExec(new Runnable() {
public void run() {
textLabel.setText(message);
splashShell.layout();
splashShell.update();
} else {
nextMessage = message;
[Updated on: Thu, 26 April 2012 05:39] by Moderator
FUDForum. Page generated in 0.09161 seconds
