XMI from java discoverer [message #855748] |
Wed, 25 April 2012 00:21  |
Hi.
I have the XMI model result of MoDisco java discoverer, but I cannot load it and navigate nor use it in ATL, since it simply does not work. When you choose that XMI from an ATL configuration as MM:IN, the content assist (ctrl+spacebar) in Eclipse ATL doesn't give me any element of the XMI model.
How can I register the java metamodel of MoDisco and then do something like:
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(Resource.Factory.Registry.DEFAULT_EXTENSION,
URI uri = URI.createFileURI(file.getAbsolutePath());//MoDisco XMI absolute path
Resource resource = resourceSet.getResource(uri,true); new XMIResourceFactoryImpl());
Thank you.
Re: XMI from java discoverer [message #855790 is a reply to message #855748] |
Wed, 25 April 2012 01:18   |
Juan,
Using XyzPackage.eINSTANCE.eClass() is an idiom for initializing the
package instance, and as a side-effect it will register itself in the
EPackage.Registry.INSTANCE, or you can use
resourceSet.getPackageRegistry().put(XyzPackage.eNS_URI,
XyzPackage.eINSTANCE). Note that Xyz is the name of the package.
On 25/04/2012 6:21 AM, Juan Castel wrote:
> Hi.
> like:
> absolute path
> Resource resource =
> Thank you.
FUDForum. Page generated in 0.04677 seconds
