| Getting java.sql.Connection from org.eclipse.datatools.modelbase.sql.tables.Table? [message #8466] |
Wed, 01 March 2006 18:02  |
I'm writing an org.eclipse.ui.popupMenus extension that is targetting the
org.eclipse.datatools.modelbase.sql.tables.Table object in Data Source
Explorer. What I would like the action to do is that if the table is JDBC
table, then use it to extract the JDBC connection information for the
connection that is containing table. The only way that I can figure out how
to do this is cast Table to
org.eclipse.datatools.connectivity.sqm.internal.core.rte.jdb c.JDBCTable and
then call getConnection to get the java.sql.Connection object which I cast
to a ConnectionAdapter. The ConnectionAdapter has a getConnectionInfo ()
which actually has what I want. My code looks something like this:
if (table isnstanceof JDBCTable)
JDBCTable jdbcTable = (JDBCTable) table;
ConnectionAdapter connection = (ConnectionAdapter)
jdbcTable.getConnection ();
ConnectionInfo info = connection.getConnectionInfo ();
String url = info.getURL ();
//etc ...
The trouble here is that I'm using JDBCTable, ConnectionAdapter and
ConnectionInfo which are all internal DTP classes.
Is it possible to get the connection information for a table using public
DTP classes?
Thanks!
Josh
| Re: Getting java.sql.Connection from org.eclipse.datatools.modelbase.sql.tables.Table? [message #8557 is a reply to message #8528] |
Thu, 02 March 2006 14:37  |
Hey Josh,
Currently, DTP only exposes a provisional API, which, at this point, is
under review. Please feel free to recommend that these classes be
included as part of the public API. (I think ConnectionInfo is part of
the public API, but has not been refactored out of its "internal" package.)
Also, if you feel other classes/interfaces would be useful to extension
developers, please recommend those as well.
Please create bugzilla entries for any API requests/changes.
Sincerely,
Rob
| Re: Getting java.sql.Connection from org.eclipse.datatools.modelbase.sql.tables.Table? [message #570953 is a reply to message #8497] |
Thu, 02 March 2006 13:39  |
Thanks for the reply Rob ... this is close, but DatabaseConnectionRegistry
and ConnectionInfo are both in the
org.eclipse.datatools.connectivity.sqm.internal.core.connect ion package ...
i.e. they're internal to the DTP plug-in. I need a way to get connection
information without using internal interfaces in DTP.
"Rob Cernich" <rcernich@sybase.com> wrote in message
news:db2c94269eb8ebb00e5deff338f58369$1@www.eclipse.org...
> Hey Josh,
> Glad to see you're trying to extend the DSE.
> Try the following:
> Schema schema = table.getSchema();
> Database database = schema.getDatabase();
> ConnectionInfo connectionInfo =
> DatabaseConnectionRegistry.getConnectionForDatabase(database );
> This method should allow you to access the ConnectionInfo object related
> to any Table (not just the specialized JDBCTable).
> Hope this helps.
> Rob
| Re: Getting java.sql.Connection from org.eclipse.datatools.modelbase.sql.tables.Table? [message #570971 is a reply to message #8528] |
Hey Josh,
Sincerely,
Rob
FUDForum. Page generated in 0.08198 seconds
