Home » Archived » BIRT » How to calculate a runningSum?
How to calculate a runningSum? [message #84734] Thu, 27 October 2005 08:23 Go to next message
I tried to get a runningSum by a group MyGroup.
The syntax, out of the documentations, is:
Syntax: runningSum( expr [, filter [, group ]] )
Here the not helpfull example, also out of the documentation:
Total.runningSum( row.OrderAmt )
But how do I enter the filter? What is the filter? Within '' or "" or what?
How do I enter the group? Within '' or "" or what?
In my current case I need just a total by MyGroup, but what I have to enter
if I need a runningSum by group but without a filter?
Total.runningSum(row["Amount"],,MyGroup) does not work. :-(
How to keep filter empty, but specify the group?
So if one is a newbee it is really hard to use predefined functions if the
documentation is that poor!
(look at the example, the function consists of 1, 2 or three params, the
example just show the obvious case with one param, not really helpful)
Thanks for any help!
Re: How to calculate a runningSum? [message #85475 is a reply to message #84734] Fri, 28 October 2005 15:35 Go to previous message
- I think runningSum has a bug, its not working as documented. Please log a
bug.
Note: The expression builder does show the function parameters and some
description for the birt java script objects.
- You could use null value, for skipping a parameter.
Total.runningSum( row.OrderAmt, null, 'grpNameCity' );
Note: If you placed the above expression in a groups footer, it will
evaluate for that group. You specify the group name if you want to use a group
other than the current group.
- Filter expression allows user to sum the rows that evaluate to true for the
given filter criteria.
- Check out the section of BIRT Java script object Total in the scripting spec.
on the BIRT website http://www.eclipse.org/birt/ref/ROM_Scripting_SPEC.pdf
--Rima Kanguri
"Mr. Burns" wrote:
> Hello,
Previous Topic:Pojo's and a scripted subreport
Next Topic:Drill-down functionality
Current Time: Sat Nov 08 13:49:49 EST 2025
Powered by FUDForum. Page generated in 0.03731 seconds
