Home » Eclipse Projects » Virgo » Spring ORM Bundle - ClassNotFoundException(javax.persistence.metamodel.Metamodel import missing on Virgo Provided bundle?)
Spring ORM Bundle - ClassNotFoundException [message #835286] Mon, 02 April 2012 22:21 Go to next message
Hi all! Im have a library that uses the javax.persistence.metamodel.Metamodel class sometimes.
This library is a normal bundle, importing the javax.persistence.metamodel package, and this import is resolved normally. But when I try to library, this exception occours:
Caused by: org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoundException: javax.persistence.metamodel.Metamodel in KernelBundleClassLoader: [bundle=org.spring
framework.orm_3.0.5.RELEASE]
        at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:138)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
        ... 56 common frames omitted
Caused by: java.lang.ClassNotFoundException: javax.persistence.metamodel.Metamodel
        at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
        at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
        at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:134)
        ... 57 common frames omitted
I see that the Manifest on org.springframework.orm-3.0.5.RELEASE bundle is missing this package import (but all other javax.persistence imports of the 2.0 spec is present). So, after add the package import with optional resolution, as the others, the application works well.
This can be a bug on the manifest header of this Virgo provided bundle?
Im using Virgo 3.0.2Release.
Re: Spring ORM Bundle - ClassNotFoundException [message #835424 is a reply to message #835286] Tue, 03 April 2012 03:33 Go to previous messageGo to next message
The org.springframework.orm-3.0.5.RELEASE bundle is provided by the Spring framework project. Perhaps you would like to contact that project to see whether this is a bug. Meanwhile, please note that you can add an import without editing the bundle by attaching a fragment, which is probably a more maintainable workaround. See this FAQ.
Re: Spring ORM Bundle - ClassNotFoundException [message #835561 is a reply to message #835424] Tue, 03 April 2012 07:51 Go to previous message
Hi Glyn! Thanks by help. I will create a fragment bundle to import this package. I need to configure this bundle inside any existing plan, or it will be activated together with Spring ORM Bundle if I put it on the Virgo repository?
I will post this question on Spring too.
Previous Topic:Replacing OSGI bundles in the running environment
Next Topic:Why is there a uses conflict without disjoint ranges?
Current Time: Fri Jun 13 15:02:43 EDT 2025
Powered by FUDForum. Page generated in 0.05341 seconds
