Home » Eclipse Projects » Remote Application Platform (RAP) » RAP 1.5 M6 based on Eclipse 4.2 , Can be installed to Eclipse3.7?
RAP 1.5 M6 based on Eclipse 4.2 , Can be installed to Eclipse3.7? [message #829364] Mon, 26 March 2012 03:36 Go to next message
Re: RAP 1.5 M6 based on Eclipse 4.2 , Can be installed to Eclipse3.7? [message #829387 is a reply to message #829364] Mon, 26 March 2012 04:14 Go to previous messageGo to next message
if you refers to the RAP Tooling, the answer is no. See bug:
366614: [Tooling] Breaking changes in the latest org.eclipse.pde.core bundle
https://bugs.eclipse.org/bugs/show_bug.cgi?id=366614
You could still develop a RAP application based on 1.5M6 RAP runtime in
Indigo (Eclipse 3.7), but should use the 1.4.2 tooling.
HTH,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: RAP 1.5 M6 based on Eclipse 4.2 , Can be installed to Eclipse3.7? [message #829425 is a reply to message #829387] Mon, 26 March 2012 05:05 Go to previous messageGo to next message
How application of the RAP Tooling?
Re: RAP 1.5 M6 based on Eclipse 4.2 , Can be installed to Eclipse3.7? [message #829709 is a reply to message #829425] Mon, 26 March 2012 13:24 Go to previous messageGo to next message
Not sure what you are asking but RAP 1.5M6 needs RAP 1.5 tooling that only works for Eclipse 4. However, you can keep using RAP 1.4 tooling in Eclipse 3.7 but manually adds the necessary bundles in your Run Configuration in order to run the UI correctly. Am I right guys?
[Updated on: Mon, 26 March 2012 13:25] by Moderator
Re: RAP 1.5 M6 based on Eclipse 4.2 , Can be installed to Eclipse3.7? [message #832798 is a reply to message #829387] Fri, 30 March 2012 11:52 Go to previous messageGo to next message
I am using Eclipse Indigo 3.7 (with RAP 1.4 tooling). I am trying to use RAP 1.5M6 as my target. I have read the bug you mentioned and I have added the Felix Gogo bundles, Jetty bundles, Equinox Console and RWT OSGi bundles to my run configuration. When I run the UI, I got the following error:
Could not process server response:
Error: Error: Operation "set" on target "w1" of type "[object Object]" failed:
b is undefined
Properties:
focusControl = com.syncsort.dp.xsb.ui.application.login.LoginDialog.textUserName
Do you know what bundle(s) are missing from my run configuration?
I have to use STS 2.9 that is based on Eclipse Indigo and I am not allowed to use Eclipse 3.8 / 4.2 yet.
Thank you.
Re: RAP 1.5 M6 based on Eclipse 4.2 , Can be installed to Eclipse3.7? [message #832860 is a reply to message #832798] Fri, 30 March 2012 13:25 Go to previous messageGo to next message
Hi Ronald,
I don't think that the problem is a missing bundle. The main difference
between 1.4 and 1.5 is the new server-to-client communication protocol.
See bug:
311355: Install a formalized communication format between server and client
https://bugs.eclipse.org/bugs/show_bug.cgi?id=311355
Do you have custom widgets in your application? What is this id:
"com.syncsort.dp.xsb.ui.application.login.LoginDialog.textUserName" ?
How this id is set in your application? Could you provide a complete
JSON from the server response that triggers this error?
Best,
Ivan
On 3/30/2012 6:52 PM, Ronald So wrote:
> failed:
> b is undefined
> Properties: focusControl =
> Thank you.
Ivan Furnadjiev
Re: RAP 1.5 M6 based on Eclipse 4.2 , Can be installed to Eclipse3.7? [message #832867 is a reply to message #832860] Fri, 30 March 2012 13:43 Go to previous messageGo to next message
Hi Ivan,
Thanks for your prompt reply. The component is just a simple Text component.
Text textUserName = new Text(parent, SWT.SINGLE);
textUserName.setData(WidgetUtil.CUSTOM_WIDGET_ID, "com.syncsort.dp.xsb.ui.application.login.LoginDialog.textUserName");
Bear with me on giving you the correct network request. I see:
operations: [,...]
0: [set, w1, {currentTheme:org.eclipse.swt.theme.Custom_2c2b3ad5, exitConfirmation:, enableUiTests:true}]
0: "set"
1: "w1"
2: {currentTheme:org.eclipse.swt.theme.Custom_2c2b3ad5, exitConfirmation:, enableUiTests:true}
currentTheme: "org.eclipse.swt.theme.Custom_2c2b3ad5"
enableUiTests: true
exitConfirmation: ""
Then a bunch of other things, then:
23: [set, w1, {focusControl:com.syncsort.dp.xsb.ui.application.login.LoginDialog.textUserName}]
0: "set"
1: "w1"
2: {focusControl:com.syncsort.dp.xsb.ui.application.login.LoginDialog.textUserName}
focusControl: "com.syncsort.dp.xsb.ui.application.login.LoginDialog.textUserName"
24: [call, w1, measureStrings, {strings:[[-1386268443, , [Arial], 13, false, false, 442, false],...]}]
0: "call"
1: "w1"
2: "measureStrings"
3: {strings:[[-1386268443, , [Arial], 13, false, false, 442, false],...]}
strings: [[-1386268443, , [Arial], 13, false, false, 442, false],...]
0: [-1386268443, , [Arial], 13, false, false, 442, false]
1: [1156581705, Log in with your company user ID and password, [Arial], 13, false, false, -1, false]
2: [1156595438, Log in with your company user ID and password, [Arial], 13, false, false, 442, false]
3: [-1383887365, OK, [Arial], 13, false, false, -1, false]
4: [-1356431594, , [Arial], 13, false, false, -1, false]
5: [897650737, User ID, [Arial], 13, true, false, -1, false]
6: [1899328188, Password, [Arial], 13, true, false, -1, false]
7: [-1386282176, , [Arial], 13, false, false, -1, false]
Do you have enough information?
Re: RAP 1.5 M6 based on Eclipse 4.2 , Can be installed to Eclipse3.7? [message #832881 is a reply to message #832860] Fri, 30 March 2012 14:08 Go to previous messageGo to next message
I also see a stack trace at the end of the message ..
  Stack: Error: Operation "set" on target "w1" of type "[object Object]" failed:
Cannot call method 'isSeeable' of undefined
Properties:
    at Object._processError (http://localhost:8080/rwt-resources/rap-client-d38c0d8f.js:254:2725)
    at Object.processOperationArray (http://localhost:8080/rwt-resources/rap-client-d38c0d8f.js:254:649)
    at Object.processMessage (http://localhost:8080/rwt-resources/rap-client-d38c0d8f.js:254:159)
    at [object Object]._handleCompleted (http://localhost:8080/rwt-resources/rap-client-d38c0d8f.js:146:3454)
    at [object Object]._dispatchEvent (http://localhost:8080/rwt-resources/rap-client-d38c0d8f.js:17:2060)
    at [object Object].dispatchEvent (http://localhost:8080/rwt-resources/rap-client-d38c0d8f.js:17:1445)
    at [object Object]._oncompleted (http://localhost:8080/rwt-resources/rap-client-d38c0d8f.js:119:2333)
    at [object Object]._oncompleted (http://localhost:8080/rwt-resources/rap-client-d38c0d8f.js:111:1776)
  Debug: off
  Request: 63532386=635%2C15&63532387=607%2C15&rwt_initialize=true&w1.bounds.width=1920&w1.bounds.height=318&w1.dpi.x=96&w1.dpi.y=96&w1.colorDepth=24&w1.cursorLocation.x=0&w1.cursorLocation.y=0&uiRoot=w1
Re: RAP 1.5 M6 based on Eclipse 4.2 , Can be installed to Eclipse3.7? [message #832887 is a reply to message #832867] Fri, 30 March 2012 14:11 Go to previous messageGo to next message
Roland,
I think that you are running into this bug:
375246: Can't set custom widget id's
https://bugs.eclipse.org/bugs/show_bug.cgi?id=375246
It exists in 1.5M6, but I fixed it this week. Could you try without
setting a custom id? If custom ids are important for your project, get
latest runtime nightly build from [1], where the bug is fixed.
[1] http://www.eclipse.org/rap/downloads/
HTH,
Ivan
On 3/30/2012 8:43 PM, Ronald So wrote:
> Hi Ivan,
> component.
> operations: [,...]
> 0: "set"
> 1: "w1"
> enableUiTests: true
> 23: [set, w1,
> 0: "set"
> 1: "w1"
> 2:
> focusControl:
> 0: "call"
> 1: "w1"
> 2: "measureStrings"
Ivan Furnadjiev
Re: RAP 1.5 M6 based on Eclipse 4.2 , Can be installed to Eclipse3.7? [message #832932 is a reply to message #832887] Fri, 30 March 2012 15:11 Go to previous messageGo to next message
Yup that's it. I commented out all the code that sets the ID and the application runs fine again. What a bummer! We love some of these new features in M6 (especially on markups) but this ID is critical for us due to our UI automation tests. Without these IDs, none of our automated tests will work!
Is this bug going to be fixed in M7? When can we expect it? How stable it is for us to develop our software on the nightly build? I am a little skeptical to use nightly builds because we are writing production code and I want the RAP framework to be as stable as possible for my UI developers.
Thanks!
Re: RAP 1.5 M6 based on Eclipse 4.2 , Can be installed to Eclipse3.7? [message #832941 is a reply to message #832932] Fri, 30 March 2012 15:24 Go to previous messageGo to next message
Ah okay the bug fix is available in the nightly build. I guess my remaining question is if the nightly build is stable enough for us to develop production code on. I will download a copy and test this out.
Thanks!
Re: RAP 1.5 M6 based on Eclipse 4.2 , Can be installed to Eclipse3.7? [message #832950 is a reply to message #832932] Fri, 30 March 2012 15:25 Go to previous messageGo to next message
Roland,
this bug is already fixed in CVS HEAD and the fix will be part of 1.5M7
(May 11) ofcourse. Our main rule is to keep the CVS stable. We have more
than 4500 JUnit server-side tests + 2000 client-side javascript tests to
ensure this. Ofcourse, milestone/release builds are more stable as we
have more time to test after a new feature is implemented. Probably,
some developers, that are working against CVS HEAD will give you an
overview how stable they find the nightly.
BTW... you don't need to comment all the code that set the custom ids.
Just set the system property org.eclipse.rwt.enableUITests temporary to
false.
Best,
Ivan
> Thanks!
Ivan Furnadjiev
Re: RAP 1.5 M6 based on Eclipse 4.2 , Can be installed to Eclipse3.7? [message #832951 is a reply to message #832950] Fri, 30 March 2012 15:32 Go to previous messageGo to next message
> false.
Smile My brain does not work well on Fridays.
Thanks so much for your quick help!
Re: RAP 1.5 M6 based on Eclipse 4.2 , Can be installed to Eclipse3.7? [message #841082 is a reply to message #832950] Tue, 10 April 2012 18:10 Go to previous messageGo to next message
Hey Ivan,
I am using RAP 1.5_m6 plus 7 fixes (nightly build March 30). I hit into a similar problem when I have enableUITest set to true. When I set enableUITest to false, the problem goes away. We only get this error when we follow a very specific click sequence.
View 1 -> View 2 -> Click Add -> TitleAreaDialog launched -> Click Close -> Navigate to View 1 then error occurred. If we do not go to TitleAreaDialog pop up, we are not able to see this problem.
Here is the error on the screen.
Error: Error: Operation "set" on target "com.syncsort.dp.xsb.ui.views.view1.nodeListTableViewer" of type "null" failed:
a is undefined
Properties:
tabIndex = 319
  Script: {
"meta": {
"requestCounter": 18
"operations": [ [ "set", "w37", {
"activeControl": "com.syncsort.dp.xsb.ui.views.view1.nodeListTableViewer"
} ], [ "set", "w87", {
"tabIndex": -1,
"visibility": false
} ], [ "set", "w88", {
"visibility": false
} ], [ "set", "com.syncsort.dp.xsb.ui.views.view2.composite2.policyListTableViewer", {
"tabIndex": -1
} ], [ "set", "w44", {
"tabIndex": 315,
"visibility": true
} ], [ "set", "w45", {
"visibility": true
} ], [ "set", "com.syncsort.dp.xsb.ui.views.view1.nodeListTableViewer", {
"tabIndex": 319
} ], [ "set", "w1", {
"focusControl": "com.syncsort.dp.xsb.ui.views.view1.nodeListTableViewer"
} ], [ "set", "uicb", {
"active": true
  fileName: http://127.0.0.1:8080/rwt-resources/rap-client-3e053963.js
  lineNumber: 254
  Stack: ([object Error],[object Array])@http://127.0.0.1:8080/rwt-resources/rap-client-3e053963.js:254
([object Array])@http://127.0.0.1:8080/rwt-resources/rap-client-3e053963.js:254
([object Object])@http://127.0.0.1:8080/rwt-resources/rap-client-3e053963.js:254
([object Object])@http://127.0.0.1:8080/rwt-resources/rap-client-3e053963.js:146
([object Object],(void 0))@http://127.0.0.1:8080/rwt-resources/rap-client-3e053963.js:17
([object Object])@http://127.0.0.1:8080/rwt-resources/rap-client-3e053963.js:17
([object Object])@http://127.0.0.1:8080/rwt-resources/rap-client-3e053963.js:119
([object Object])@http://127.0.0.1:8080/rwt-resources/rap-client-3e053963.js:111
("completed","receiving")@http://127.0.0.1:8080/rwt-resources/rap-client-3e053963.js:112
anonymous("completed")@http://127.0.0.1:8080/rwt-resources/rap-client-3e053963.js:12
([object Object])@http://127.0.0.1:8080/rwt-resources/rap-client-3e053963.js:112
([object Object],true)@http://127.0.0.1:8080/rwt-resources/rap-client-3e053963.js:17
("completed")@http://127.0.0.1:8080/rwt-resources/rap-client-3e053963.js:17
("completed","receiving")@http://127.0.0.1:8080/rwt-resources/rap-client-3e053963.js:115
([object Event])@http://127.0.0.1:8080/rwt-resources/rap-client-3e053963.js:115
([object Event])@http://127.0.0.1:8080/rwt-resources/rap-client-3e053963.js:15
  Debug: off
  Request: w47.selectedItemId=w67&org.eclipse.swt.events.widgetSelected=w47&w1.cursorLocation.x=141&w1.cursorLocation.y=82&uiRoot=w1&requestCounter=17
Re: RAP 1.5 M6 based on Eclipse 4.2 , Can be installed to Eclipse3.7? [message #841342 is a reply to message #841082] Wed, 11 April 2012 03:11 Go to previous messageGo to next message
Hi Roland,
without a snippet to reproduce the problem I can't help you much. Please
file a bugzilla and attach a snippet to reproduce the problem there.
Ivan
On 4/11/2012 1:10 AM, Ronald So wrote:
> Hey Ivan,
> "null" failed:
> a is undefined
> Properties: tabIndex = 319
> Script: {
> "meta": {
> "tabIndex": -1,
> "visibility": false
> "visibility": false
> } ], [ "set",
> "tabIndex": -1
> "tabIndex": 315,
> "visibility": true
> "visibility": true
> "tabIndex": 319
> "active": true
> lineNumber: 254
> ([object
> ([object
> ([object
> ([object
> ([object
> ([object
> ([object
> ([object
> ([object
> ([object
> ([object
> ([object
> Debug: off
> Request:
Ivan Furnadjiev
Re: RAP 1.5 M6 based on Eclipse 4.2 , Can be installed to Eclipse3.7? [message #849052 is a reply to message #841342] Wed, 18 April 2012 16:59 Go to previous message
Thanks Ivan. I have logged a bug with the code that you can reproduce the problem.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=377127
Previous Topic:UI callback and session expiring
Next Topic:Table inside ExpandBar not generating mouse events properly
Current Time: Sun Jul 20 15:05:11 EDT 2025
Powered by FUDForum. Page generated in 0.08543 seconds
