| Re: migrating to Xtext 2.3 and ITreeAppendable [message #828478 is a reply to message #827423] |
Sat, 24 March 2012 17:51   |
Hi Lorenzo,
yes you can use that but you won't get debugging for free.
TreeAppendable is the actual implementation, but it imposes some
constraints on how you use the compiler. If you don't need the tracing
and jsr45 stuff, FakeTreeAppendable is the way to go.
Sebastian
Am 23.03.12 06:04, schrieb Lorenzo Bettini:
> On 03/23/2012 03:35 AM, Sebastian Zarnekow wrote:
>> Hi Lorenzo,
>> what do you want to do? The appendable is created by the framework and
>> passed to clients.
>> Regards,
>> Sebastian
> Hi Sebastian
> in this DSL I'm not using the inferrer (for the moment) and I have a
> custom xbase compiler which I call from the generator, thus I have to
> create the appendable myself...
> Is FakeTreeAppendable the right substitute?
> thanks in advance
> Lorenzo
| Re: migrating to Xtext 2.3 and ITreeAppendable [message #1146533 is a reply to message #828478] |
Sun, 20 October 2013 03:52  |
Dear All,
I need your favor or suggestion regarding migrate the xtext version from 1.0.1 to 2.3.0 in custom application.
I followed all following process for migrate the xtext version.
1. Delete the old plug-ins and update the latest plug-ins in target platform.
2. Update the Plug-in Dependencies and Import Statements.
3. Introduction of the Qualified Name.
4. Changes in the index and in find references.
5. Rewritten Node Model.
6. AutoEditStrategy.
7. Other Noteworthy API Changes
To consider the above steps, I started the work with Eclipse-4.2, Which has a xtext-2.3.0 dependency. Successfully I completed the all above steps and removed the compilation error.
Problem: After that I start the testing and getting below error Messages:
[XtextLinkingDiagnostic: null:6 Couldn't resolve reference to Material 'MPS_RECUR'.,
XtextLinkingDiagnostic: null:9 Couldn't resolve reference to Cstic 'NUM_OF_ALLOC'.,
XtextLinkingDiagnostic: null:15 Couldn't resolve reference to Cstic 'INSTANCE_NUM'.,
XtextLinkingDiagnostic: null:14 Couldn't resolve reference to Class 'ALLOC'.]
FUDForum. Page generated in 0.06997 seconds
