Home » Language IDEs » Java Development Tools (JDT) » segmentation fault indigo SR2 with glassfish 3.1.2 plugin
segmentation fault indigo SR2 with glassfish 3.1.2 plugin [message #824601] Mon, 19 March 2012 17:29 Go to next message
I am persistently getting a repeatable segmentation fault crash when I run a simple project using the internal Glassfish server plugin and then attempt to navigate to any Java source file. If I open a Java file prior to running the project on the server, then I am able to switch to the window, but the segmentation fault happens when I make any simple code change.
It is so unstable it is unworkable. The segmentation fault happens with pretty much anything I try to do.
Operating System: Ubuntu 11.10 32-bit
Java Version: 1.7.0_03
Glassfish Plugin:
Eclipse Version: Indigo SR2 (this was happening with SR1 also)
Glassfish Application Server: Version 3.1.2.0 from the server download.java.net and directory /glassfish/eclipse/indigo (I am not allowed to post links yet)
(I downloaded the latest versions of all of the above today itself)
Re: segmentation fault indigo SR2 with glassfish 3.1.2 plugin [message #824629 is a reply to message #824601] Mon, 19 March 2012 18:15 Go to previous messageGo to next message
is this the right forum to get help? please tell me where i should report this or ask for help to get around this. thank you!
Re: segmentation fault indigo SR2 with glassfish 3.1.2 plugin [message #825182 is a reply to message #824629] Tue, 20 March 2012 11:20 Go to previous messageGo to next message
Asking in Platform/SWT forum or Glassfish could help.
Re: segmentation fault indigo SR2 with glassfish 3.1.2 plugin [message #825337 is a reply to message #825182] Tue, 20 March 2012 14:42 Go to previous message
thank you
Previous Topic:How to customise ctrl-f key
Next Topic:Eclipse Resource on compilation error
Current Time: Sat Jul 26 20:09:08 EDT 2025
Powered by FUDForum. Page generated in 0.04305 seconds
