Home » Modeling » GMF (Graphical Modeling Framework) » Fixed a size of an Ellipse
Fixed a size of an Ellipse [message #813077] Sun, 04 March 2012 15:21 Go to next message
Hello everyone;
please how i can fix a size of a figure (i want create a constant size of a figure elipse for example ).
I tried with maximun size and minimum size but the size of the figure is not fixed
Re: Fixed a size of an Ellipse [message #813434 is a reply to message #813077] Mon, 05 March 2012 04:03 Go to previous messageGo to next message
I am not sure you need ALL of the list above, but it will not hurt and it is proven to work. So,
- set the min-, max-, and preferred- size to required dimension for Figure
- set Node's resize constraint to Direction.NONE
- create the DefaultSize facet with the desired size inside the corresponding Node
Michael "Borlander" Golubev
at Montages Think Tank, Prague, Czech Republic
Re: Fixed a size of an Ellipse [message #813440 is a reply to message #813077] Mon, 05 March 2012 04:09 Go to previous messageGo to next message
Hi Lamia,
what do you mean with fix size? Do you want to disable resizing of a figure?
This can be done by installing a NonResizableEditPolicy to your figures edit part.
Unfortunatelly, this does not prevent the user to set a custom size during creation of the element. To disable this you can override the getCreateElementAndViewCommand method in the parents CreationEditPolicy like this:
protected Command getCreateElementAndViewCommand(
	CreateViewAndElementRequest request) {
String semanticHint = request.getViewAndElementDescriptor().getSemanticHint();
if (semanticHint == MyFigure)){
   request.setSize(new Dimension(-1, -1));
return super.getCreateElementAndViewCommand(request);
Maybe there is a better way to prevent resizing on creation?
Andreas
Re: Fixed a size of an Ellipse [message #814431 is a reply to message #813440] Tue, 06 March 2012 07:52 Go to previous message
Hi Michael & Andreas;
thnks alot for the help.
yes Andreas i want to disable resizing a figure.
I tried with the method of Michael and I managed.
Previous Topic:images and gmf
Next Topic:failed to create a view
Current Time: Sat Jul 19 14:38:23 EDT 2025
Powered by FUDForum. Page generated in 0.04246 seconds
