Home » Language IDEs » Java Development Tools (JDT) » How to neatly format if..else without an else-if
How to neatly format if..else without an else-if [message #810777] Thu, 01 March 2012 09:47 Go to next message
In the formatter I can specify to place 'then' statements on the next line
if (false)
	return;
else
	return;
and I can specify to keep 'else if' on the same line, which is kind of an exception (because the second if-else structure is in fact a single 'then' statement).
if (true)
	return;
else if (false)
	return;
else
	return;
But whenever this second if structure doesn't have an else, things get weird.
I want if statements without an else to be on the same line, which I can specify with the 'simple if' setting
if (true) return;
however, in the case an 'else' statement is a simple if, I would like to have it on the next line as if it is a single big if-elseif structure:
if (true)
	return;
else if (false)
	return;
How can I configure the formatter so it will keep the following example exactly as it is (no change when I execute the formatter)?
if (true) return;
if (true)
	return;
else if (false)
	return;
If it is not possible, I would like to request this feature.
[Updated on: Thu, 01 March 2012 09:50] by Moderator
Re: How to neatly format if..else without an else-if [message #811229 is a reply to message #810777] Thu, 01 March 2012 23:26 Go to previous messageGo to next message
In the 'Control Statements' block only turn on 'Keep simple 'if' on one line' and 'Keep 'else if' on one line. Turn off all the options.
Re: How to neatly format if..else without an else-if [message #811261 is a reply to message #811229] Fri, 02 March 2012 00:28 Go to previous messageGo to next message
Doesn't work. It turns the last part into this ugly being:
if (true)
	return;
else if (false) return;
Re: How to neatly format if..else without an else-if [message #811447 is a reply to message #811261] Fri, 02 March 2012 05:58 Go to previous messageGo to next message
It's a good practice to put the open and close brackets for if-else controls, even when the body has only one statement.
Re: How to neatly format if..else without an else-if [message #811640 is a reply to message #810777] Fri, 02 March 2012 11:29 Go to previous message
In the 'Control Statements' block turn OFF 'Keep simple 'if' on one
line' and turn ON 'Keep 'else if' on one line. Turn off all the other
options.
This would have
if (true)
return;
if (true)
return
else if (false)
return
else
return
Personally I don't like if (true) return. I find it hard to read. So
turning off makes it nice to read in all cases including by itself and
in the chained if-else cases.
Rich
Previous Topic:PatternFilter and CNF
Next Topic:Eclipse - unable to see New Java Project button as described by Cheat Sheet
Current Time: Mon Jun 16 10:41:09 EDT 2025
Powered by FUDForum. Page generated in 0.04784 seconds
