Home » Language IDEs » ServerTools (WTP) » Tomcat configuration
Tomcat configuration [message #80857] Mon, 07 March 2005 06:47 Go to next message
Originally posted by: kthunoe.io.dk
Trying to make a web service client. I add the Tomcat server as an
installed runtime. I make the project. Add a new webservice client module.
But when trying to finish the wizard I get this:
IWAB0213E Error in starting server.
org.eclipse.core.runtime.CoreException[0]:
org.eclipse.core.runtime.CoreException: Could not load the Tomcat server
configuration at \Servers\Tomcat v4.1 Server @ localhost-config. The
configuration may be corrupt or incomplete.
at
org.eclipse.jst.server.tomcat.core.internal.Tomcat41Configur ation.load(Tomcat41Configuration.java:278)
at
org.eclipse.jst.server.tomcat.core.internal.TomcatServer.get TomcatConfiguration(TomcatServer.java:81)
at
org.eclipse.jst.server.tomcat.core.internal.TomcatServer.sav eConfiguration(TomcatServer.java:115)
at
org.eclipse.wst.server.core.internal.ServerWorkingCopy.save( ServerWorkingCopy.java:243)
at
org.eclipse.wst.server.core.internal.ServerWorkingCopy.saveA ll(ServerWorkingCopy.java:255)
at
org.eclipse.jst.ws.internal.common.ServerUtils.modifyModules (ServerUtils.java:151)
at
org.eclipse.jst.ws.internal.consumption.command.common.Creat eWebProjectCommand.execute(CreateWebProjectCommand.java:161)
at
org.eclipse.jst.ws.internal.consumption.command.common.Creat eClientProjectCommand.execute(CreateClientProjectCommand.jav a:133)
at
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.runCommand(CommandFragmentEngine.java:322)
at
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.visitTop(CommandFragmentEngine.java:288)
Can anyone help with this?
Thanks in advance!
Re: Tomcat configuration [message #80861 is a reply to message #80857] Mon, 07 March 2005 08:47 Go to previous messageGo to next message
Assuming you are using M3, Tomcat41Configuration throws an exception at
line 278 if the "catalina.policy" file doesn't exist in the server
configuration, i.e. in the "\Servers\Tomcat v4.1 Server @
localhost-config" directory in your case. I can't say why it isn't there.
Larry
> module. But when trying to finish the wizard I get this:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks in advance!
Re: Tomcat configuration [message #80879 is a reply to message #80861] Mon, 07 March 2005 09:58 Go to previous message
I got it worked out just a minute ago. I was missing the Servers\...
section in the workspace and therefore also missing the files
(catalina.policy, server.xml etc.) I solved it by explicitly adding a new
"Server" into workspace.
Thanks for replying though :)
> configuration, i.e. in the "ServersTomcat v4.1 Server @
> Larry
>> configuration at ServersTomcat v4.1 Server @ localhost-config. The
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Thanks in advance!
Previous Topic:Click to open file doesn't work in J2EE perspective
Next Topic:WTP M3: what is the deal with the install process? (long)
Current Time: Fri Oct 24 04:57:10 EDT 2025
Powered by FUDForum. Page generated in 0.04642 seconds
