Home » Eclipse Projects » Equinox » RequestDispatcherAdaptor NullPointerException
RequestDispatcherAdaptor NullPointerException [message #79507] Tue, 19 December 2006 09:06 Go to next message
Originally posted by: ridcully560.yahoo.com
I ran into a problem with the RequestDispatcherAdaptor. In the webapp
I'm trying to set up for running as a bundle in Equinox, I got a
DispatcherServlet that forwards the request to other Servlets:
> getServletContext().getNamedDispatcher(
> AppointmentServlet.class.getSimpleName()).forward(request, response);
This works fine in the old version running with tomcat, but when I try
it with Equinox, I allways get the following exception:
> at org.eclipse.equinox.http.servlet.internal.RequestDispatcherA daptor.forward(RequestDispatcherAdaptor.java:19)
Which points to here, where requestDispatcher is null:
> public void forward(ServletRequest req, ServletResponse resp) throws ServletException, IOException {
> if (req instanceof HttpServletRequestAdaptor)
> req = ((HttpServletRequestAdaptor) req).getRequest();
> requestDispatcher.forward(req, resp);
In an - not answered - older post I found a hint that it might be
because of different context of the servlets. After that, I also
registered the other servlet:
> ServiceReference sr = bc.getServiceReference(HttpService.class.getName());
> if(sr != null) {
> HttpService http = (HttpService)context.getService(sr);
> if(http != null) {
> http.registerServlet("/path/MainServlet", new MainServlet(), null, null);
> http.registerServlet("/path/ForwardToServlet", new ForwardToServlet(), null, null);
But the exception still is thrown.
Maybe someone got a hint about that,
Johannes
Re: RequestDispatcherAdaptor NullPointerException [message #79524 is a reply to message #79507] Tue, 19 December 2006 11:00 Go to previous messageGo to next message
Hi Johannes,
The OSGi HttpService does not provide support or uniqueness guarantees for
registering a servlet by "name" unfortunately, just uniquesness guarantess
on the "path".
What this amounts to is that as you've found
getServletContext().getNamedDispatcher(...) will return null as there are no
named servlets to find. Even if you register with the same HttpContext this
will still return null.
All is not lost...
You can still do your Request Dispatching by "path" and I'd suggest doing
something like this instead.
getServletContext().getRequestDispatcher("/pathToAppointmentServlet ").forward(request,
response)
HTH
-Simon
"Johannes" <ridcully560@yahoo.com> wrote in message
news:em8ric$fob$1@utils.eclipse.org...
> I ran into a problem with the RequestDispatcherAdaptor. In the webapp I'm
> This works fine in the old version running with tomcat, but when I try it
>> at
> In an - not answered - older post I found a hint that it might be because
> of different context of the servlets. After that, I also registered the
> other servlet:
>> if(sr != null) {
>> if(http != null) {
>> null);
>> null, null);
> Johannes
Re: RequestDispatcherAdaptor NullPointerException [message #79596 is a reply to message #79524] Tue, 19 December 2006 12:50 Go to previous message
Hi Simon
> All is not lost...
> response)
> HTH
> -Simon
Yes, seems to work!
Johannes
Previous Topic:Host bundle exists but is unresolved
Next Topic:Init-Params
Current Time: Fri Nov 07 01:54:32 EST 2025
Powered by FUDForum. Page generated in 0.05499 seconds
