Home » Language IDEs » ServerTools (WTP) » M3 xerces classloading problem
M3 xerces classloading problem [message #78644] Tue, 01 March 2005 10:00 Go to next message
Originally posted by: fsauer.us.ibm.com
Code that previously extended M2 and functioned properly, now breaks with
exceptions like these every time I attempt
to use org.w3c.dom classes like Node and NamedNodeMap. What happened and
how do i fix it?
I did notice that you now ship xercesImpl with M3, whereas previously we
had to add it ourselves.
Is it a different version? I tried -clean and a new workspace, but this
keeps happening.
java.lang.LinkageError: Class org/w3c/dom/NamedNodeMap violates loader
constraints
at
org.eclipse.vtp.editor.actions.ActionSupport.currentPosGetAt tributeValue(ActionSupport.java:108)
at
org.eclipse.vtp.editor.actions.ActionSupport.isElementWithAt tribute(ActionSupport.java:186)
at
org.eclipse.vtp.editor.actions.ActionSupport.isElementWithNe xt(ActionSupport.java:165)
at
org.eclipse.vtp.editor.ccxml.actions.EditReferencedFileActio n.isVisible(EditReferencedFileAction.java:73)
at
org.eclipse.wst.sse.ui.internal.extension.ExtendedEditorActi onProxy.invoke(ExtendedEditorActionProxy.java:132)
at $Proxy0.isVisible(Unknown Source)
at
org.eclipse.wst.sse.ui.extension.ExtendedEditorActionBuilder $ExtendedContributor.setActiveEditor(ExtendedEditorActionBui lder.java:271)
at
org.eclipse.wst.sse.ui.StructuredTextEditor.addExtendedConte xtMenuActions(StructuredTextEditor.java:576)
at
org.eclipse.vtp.editor.StructuredVoicetoolsEditor.addExtende dContextMenuActions(StructuredVoicetoolsEditor.java:92)
at
org.eclipse.wst.sse.ui.StructuredTextEditor.editorContextMen uAboutToShow(StructuredTextEditor.java:1359)
at
org.eclipse.ui.texteditor.AbstractTextEditor$11.menuAboutToS how(AbstractTextEditor.java:2137)
at
org.eclipse.jface.action.MenuManager.fireAboutToShow(MenuMan ager.java:285)
and related:
java.lang.IncompatibleClassChangeError
at
at
at
at
at
at
org.eclipse.wst.sse.ui.extension.ExtendedEditorActionBuilder $ExtendedContributor.contributeToPopupMenu(ExtendedEditorAct ionBuilder.java:122)
at
org.eclipse.wst.sse.ui.StructuredTextEditor.addExtendedConte xtMenuActions(StructuredTextEditor.java:577)
at
at
at
at
Re: M3 xerces classloading problem [message #79132 is a reply to message #78644] Wed, 02 March 2005 10:15 Go to previous messageGo to next message
I found out a possible workaround: remove xmlParserAPIs.jar from
plugins/org.eclipse.wst.xml.validation_1.0.0/jars
and everything works fine, *including validation*. If I remove
xercesImpl.jar as well, validation stops working but with
xmlParserAPIs.jar there I get the linking problems for Node and
NamedNodeMap classes....
This brings up the following questions:
Why was this jar included ?,
Can we indeed do without ?,
Does this break something I'm not currently using?
Frank Sauer
Re: M3 xerces classloading problem [message #79379 is a reply to message #79132] Wed, 02 March 2005 14:20 Go to previous messageGo to next message
Hi Frank,
What JRE are you using? If I remember correctly there was a change in the
XML parser API between 1.4.1 and 1.4.2.
Lawrence
>Thanks,
>Frank Sauer
Re: M3 xerces classloading problem [message #79583 is a reply to message #79379] Wed, 02 March 2005 20:46 Go to previous messageGo to next message
I am using 1.4.2 on win32
Lawrence Mandel wrote:
> Hi Frank,
> Lawrence
>>Thanks,
>>Frank Sauer
Re: M3 xerces classloading problem [message #81913 is a reply to message #79583] Thu, 10 March 2005 06:37 Go to previous message
These jars were included for required/improved "validation" checking.
You can live without if you don't need XML Schema validation, or if you
are, somehow, supplying another equivelent version of xerces on your classpath.
You may also want to follow bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=87621
as some classloader issues are explored.
By next milestone, we plan to have xerces plugin in the plugin "stack" like
Eclipse base used to have, and, eventually, some ability to update it to newer versions
of xerces as they become available.
I suspect there will continue to be issues in this area so appreciate your early/thourogh testing.
In general, one contraint (that is solution) may be that some plugins in pre-req chain may have to
be in a certain order.
Previous Topic:external libs
Next Topic:whats this problem with html editor
Current Time: Sat Jul 19 15:03:34 EDT 2025
Powered by FUDForum. Page generated in 0.03909 seconds
