Blueprint - Can I use Apache Aries? [message #792733] |
Tue, 07 February 2012 05:48  |
Hi all!
I'm working on a new project, and I belive that is better to focus on the standard Blueprint instead SpringDM (even when both is very similar).
I try to deploy Gemini Blueprint 1.0.0.Release on Virgo 3.0.2.Release, but sometimes in startup, Many errors occours, about Spring conflicts. I belive that is because the native support of Gemini to SpringDM, that is already present on Virgo.
So, I try to use Apache Aries 0.3. With my simple tests, it is working. I only create a PLAN, and deployed it before the UserRegion Bundles starts.
But i've read on a blog entry (http://underlap.blogspot.com/2011/07/virgo-30-maya-release-candidate-1.html), where Glyn Normington don't recommend the use of this implementation.
There's some incompatibility when running this implementation on Virgo? Can I trust on stability on a production environment?
I want to start the development using Aries blueprint, at least until Virgo does not adopt the Gemini Blueprint.
Thanks!
Eduardo
FUDForum. Page generated in 0.03868 seconds
