Home » Language IDEs » ServerTools (WTP) » Still can't start Tomcat
| Still can't start Tomcat [message #79010] |
Wed, 02 March 2005 06:34  |
Originally posted by: fassev.gmx.de
Hello Mohammad, Hello Larry,
thank your very match for your suggestions, but I am still not able to
start the Tomcat. I tried with 5.0 and 5.5 but I am getting the same
message:
java.lang.NoClassDefFoundError: org/apache/catalina/startup/Bootstrap
I used three different directories:
E:\Programme\Tomcat5.0
E:\Programme\Tomcat5.5
E:\Tomcat5.5
With all of them I can compile and change my program, but I am not able to
run or debug it. Where or how can I find the starting parameter of the
Tomcat within Eclipse? Where can I see a start log?
I am currently working with NetBeans 3.6 on a large project, where the
integration and configuration of Tomcat is more simple and clear (at least
for me). There I can see and control the Context of my Web-Project. Within
Eclipse I am not seeing it (at least not in the UI) so what if I am
running multiple projects? Nevertheless, I love Eclipse and I am looking
forward to see a good WEB Tool integrated within it.
Best Regards
Peter
Muhammad Dwyer wrote:
> Dear Larry,
> Thank you very much! I've now got my first JSP running on Tomcat under
Eclipse!
> I can now move onto some more serious stuff. Excellent, thanks again.
> Kind regards,
> Muhammad
>> I was able to duplicate this. Drop the trailing '' and just use
>> "E:jakarta-tomcat-5.0.28" and it should work. The extra '' causes
>> the launch configuration to contain "...bin" rather than
>> "...binbootstrap.jar" in the classpath.
>> You can either delete and re-create the server, or execute Window ->
>> Preferences and select Server -> Installed Runtimes -> "your runtime"
>> and click Edit. Remove the trailing '' from the installation
>> directory and save.
>> I'll see about logging a defect and providing a patch.
>> Cheers,
>> Larry
>>> Hello Lawrence,
>>> My tomcat installation directory is E:jakarta-tomcat-5.0.28 - this
>>> is also how I entered it in the "Edit Server Runtime" dialog -
>>> otherwise eclipse won't let you get any further.
>>>> Hi Peter,
>>>> Are you specifying the root directory of you Tomcat install as the
>>>> install location? If so, what is the directory name? There was a
>>>> post above that suggested the directory name must be as creates it
>>>> when you unzip.
>>>> Lawrence
>>>>> Hello,
>>>>> I downloaded and installed the new M3 build of the WTP and created
>>>>> a new Web Project as showed in the Tutorial "WTP Tutorials -
>>>>> Building a School Schedule Web Application". Everything goes ok,
>>>>> except that I am not able to start the Tomcat 5.0. I am getting
>>>>> Class not found Exceltion :
>>>>> Looking at the Tomcat v5.0 runtim configuration within my project,
>>>>> I do not see the bootstrap.jar, commons-launcher.jar,
>>>>> commons-daemmon.jar -
>>>> all
>>>>> of them laying in the Tomcat5.0/bin directory.
>>>>> What I am doing wrong?
>>>>> Best Regards
>>>>> Peter
| Re: Still can't start Tomcat [message #79054 is a reply to message #79010] |
Wed, 02 March 2005 08:13   |
Peter,
You can view the launch configuration by executing Run -> Run... and
selecting the configuration under Apache Tomcat. If you don't see
anything unusual, attach or include a copy of the configuration file
found under
<your_workspace_dir>\.metadata\.plugins\org.eclipse.debug.core\.launches
and I'll see if I can spot anything.
Larry
> message:
> E:\Tomcat5.5
> to run or debug it. Where or how can I find the starting parameter of
> the Tomcat within Eclipse? Where can I see a start log?
> least for me). There I can see and control the Context of my
> Web-Project. Within Eclipse I am not seeing it (at least not in the UI)
> so what if I am running multiple projects? Nevertheless, I love Eclipse
> and I am looking forward to see a good WEB Tool integrated within it.
> Best Regards
> Peter
<snip>
| Re: Still can't start Tomcat [message #79241 is a reply to message #79054] |
Wed, 02 March 2005 11:47   |
Hello Larry,
thanks for your helpfulness. I looked at the most files within the
metadata folder, but I couldnt find anything suspicious. Here is my
launch configuration:
<launchConfiguration
type="org.eclipse.jst.server.tomcat.core.launchConfigurationType ">
<stringAttribute key="server-id" value="02.03.05_16_393"/>
<booleanAttribute key="org.eclipse.debug.core.appendEnvironmentVariables"
value="true"/>
</launchConfiguration>
The only thing I am wondering, is that within the file
metadata\.plugins\org.eclipse.core.runtime\.settings\org.ecl ipse.jdt.core.prefs
the entry
//org.eclipse.jdt.core.classpathContainer.Infobase|org.eclip se.jst.server.core.container/org.eclipse.jst.server.tomcat.r untimeTarget/Apache\
Tomcat\ v5.0=
contains too few class path entries, for instance nothing about the
missing file "bootstrap.jar".
As I previously stated, within Eclipse I have Tomcat 5.0 runtime Entry
within my project with only few jars, actually only those found within the
common/lib directory of the Tomcat. The bin and the server/lib
directory are completely missing!? Can I add them manually?
At the end, I simply added all Tomcat5 jars to the class path (tried both
bootstrap and user entries) of the Debug-Launch-Configuration, but as
expected this was not the right solution. At least I am getting another
exception now:
Can't load server.xml
02.03.2005 17:28:18 org.apache.catalina.startup.Catalina start
INFO: Server startup in 0 ms
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 84)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:42 2)
at org.apache.catalina.startup.Catalina.await(Catalina.java:619 )
at org.apache.catalina.startup.Catalina.start(Catalina.java:579 )
... 6 more
Looking within the Server folder at the Eclipse Project I can find the
local created server configuration: Tomcat v5.0 Server @ localhost-config.
Sorry I cant find, what am I doing wrong. May be I messed it completely
(although I thought, this happens only to newbies
Best Regards
Peter
Larry Isaacs wrote:
> Peter,
> found under
> <your_workspace_dir>.metadata.pluginsorg.eclipse.debug.core.launches
> Cheers,
> Larry
>> message:
>> E:ProgrammeTomcat5.0
>> E:ProgrammeTomcat5.5
>> E:Tomcat5.5
>> Best Regards
>> Peter
> <snip>
| Re: Still can't start Tomcat [message #79348 is a reply to message #79241] |
Wed, 02 March 2005 13:15   |
Hi Peter,
First, it is normal not to see the startup jars in your Tomcat runtime.
Only jars that are in common\lib should appear. Your webapp
shouldn't need to compile against bootstrap.jar. Not seeing them has
nothing to do with the launch problems.
The launch configuration you show unfortunately isn't the one I'm
looking for. There should be one named something like "Tomcat v5.0
Server _ localhost.launch" that has the actual Tomcat launch
configuration. Do you have one of those?
I am also assuming that this Tomcat runs fine from the startup scripts
in its bin directory. Preferably with the same JDK that the Tomcat
server in Eclipse is configured to use.
Larry
Peter wrote:
> Hello Larry,
> metadata folder, but I couldn't find anything suspicious. Here is my
> <booleanAttribute
> key="org.eclipse.debug.core.appendEnvironmentVariables" value="true"/>
> the entry
> //org.eclipse.jdt.core.classpathContainer.Infobase|org.eclip se.jst.server.core.container/org..eclipse.jst.server.tomcat. runtimeTarget/Apache\
> Tomcat\ v5.0=
> As I previously stated, within Eclipse I have "tomcat 5.0 runtime" Entry
> the common/lib directory of the Tomcat. The "bin" and the "server/lib"
> both bootstrap and user entries) of the Debug-Launch-Configuration, but
> as expected this was not the right solution. At least I am getting
> another exception now:
> at
> at
> ... 6 more
> Sorry I can't find, what am I doing wrong. May be I messed it completely
> (although I thought, this happens only to newbies)
> Best Regards
> Peter
> Larry Isaacs wrote:
>> Peter,
>> found under
>> Cheers,
>> Larry
>>> to start the Tomcat. I tried with 5.0 and 5.5 but I am getting the
>>> same message:
>>> E:Tomcat5.5
>>> able to run or debug it. Where or how can I find the starting
>>> parameter of the Tomcat within Eclipse? Where can I see a start log?
>>> the integration and configuration of Tomcat is more simple and clear
>>> (at least for me). There I can see and control the Context of my
>>> UI) so what if I am running multiple projects? Nevertheless, I love
>>> Eclipse and I am looking forward to see a good WEB Tool integrated
>>> within it.
>>> Best Regards
>>> Peter
>> <snip>
| Re: Still can't start Tomcat [message #79778 is a reply to message #79348] |
Thu, 03 March 2005 09:44  |
Hi Larry,
sorry for my late answer, but I am working at the same time on my project,
so I have only limited time to look at the eclipse problem.
I have looked for the requested file, but there was nothing like this. I
suppose, because the Tomcat hasn't been started at all.
After that I reinstalled the Tomcat 5.0.29 into a new directory, deleted
all files from the workspace (manually) and started from scratch. The good
news is, that I am able to start the Tomcat now. The bad one is, I am
still not able to start my actual project. When I have time, I will look
into it, I hope this is some configuration issue.
Still it is a little bit annoying, that eclipse does not recognize only
new tomcat installations. I must admin, that I have edited the server.xml
and the web.xml of the previous installations, but why should be this a
problem at all?
Best regards
Peter
Larry Isaacs wrote:
> Hi Peter,
> Only jars that are in commonlib should appear. Your webapp
> Larry
Current Time: Wed Nov 19 00:11:36 EST 2025
Powered by FUDForum. Page generated in 0.04937 seconds
