Home » Eclipse Projects » Remote Application Platform (RAP) » RAP | Mobile | Menu
RAP | Mobile | Menu [message #783970] Thu, 26 January 2012 16:19 Go to next message
I am trying to move the current RAP application to mobile
1. Can we create the cutom widgets which uses
(http://demo.qooxdoo.org/1.6/apiviewer/#qx.ui.mobile)
so that application runs on the mobile..
2.Secondly, the client side footprint can be reduced accroding to the below posting
http://www.eclipse.org/forums/index.php/m/72170/?srch=mobile#msg_70574
If i remove the Tree and i am using the Table , how much will be the difference.
Raj
Re: RAP | Mobile | Menu [message #786481 is a reply to message #783970] Mon, 30 January 2012 08:40 Go to previous messageGo to next message
Not possible since the qooxdoo version is not compatible with RAP
qooxdoo. If you are missing specific features in RAP open an enhancement
request or implement a custom widget yourself in the current RAP qooxdoo
client.
> below posting
> difference.
This post is very, very out-of-date. If you want to remove some
components from the client this is still possible (in a different way),
but it will only save a few KB on the client js file, which is cached
and compressed anyway. Not recommanded.
Greetings,
Tim
Re: RAP | Mobile | Menu [message #786812 is a reply to message #786481] Mon, 30 January 2012 16:01 Go to previous messageGo to next message
Hi Tim
Thanks for saving me couple of hours for letting me know that it is not worth spending time on doing the custom build.
Can you let me know RAP 1.5M4 uses which version of the qooxdoo java script library ?
Raj
Re: RAP | Mobile | Menu [message #786816 is a reply to message #786481] Mon, 30 January 2012 16:02 Go to previous messageGo to next message
Hi Tim
Raj
Re: RAP | Mobile | Menu [message #787343 is a reply to message #786816] Tue, 31 January 2012 08:23 Go to previous messageGo to next message
Am 30.01.2012 22:02, schrieb Raj:
> Hi Tim
> script library ?
RAP qooxdoo is not fully compatible with any other version of qooxdoo
since its heavily cutomized, partially rewritten and missing some
components. It was originally based on qooxdoo 0.7.4.
> Thanks
> Raj
Re: RAP | Mobile | Menu [message #788833 is a reply to message #787343] Thu, 02 February 2012 04:23 Go to previous message
Hi Raj,
it's probably possible to write custom widgets for RAP based on the
qooxdoo code you mentioned. But as Tim pointed out, this will require
much more work than just copying the qooxdoo files. You should be
familiar with RAP, JavaScript, and qooxdoo if you start this effort.
Moreover, we are still in the process of consolidating our client
structure, so you may have to adapt your custom widget to changes in
future versions.
Regards, Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Previous Topic:CoolBar space visible even after setting visible to false
Next Topic:Using the SVN Team Provider with RAP
Current Time: Sun Jul 20 12:48:45 EDT 2025
Powered by FUDForum. Page generated in 0.04230 seconds
