Home » Language IDEs » Java Development Tools (JDT) » Problem Executing SWT Tutorial in Eclipse Java IDE(Plug-in Development option appears to be missing)
Problem Executing SWT Tutorial in Eclipse Java IDE [message #778609] Fri, 13 January 2012 09:03 Go to next message
I thought I'd run this by you before I reported it as a bug. I think that I probably don't have something configured correctly.
When I try to go through the SWT tutorial and I'm instructed to go to Import>Plug-in Development this option appears to be missing. As a result, I'm unable to complete the tutorial.
I have described it in more detail here:
h ttp://www.java-forums.org/new-java/53817-having-problems-getting-started-eclipse.html
Your help will be greatly welcomed in figuring this out. Thx.
*should I report in bugzilla?
-moby
Re: Problem Executing SWT Tutorial in Eclipse Java IDE [message #779604 is a reply to message #778609] Mon, 16 January 2012 01:26 Go to previous messageGo to next message
You need to install the PDE feature. Go through Help->Install Software.
Re: Problem Executing SWT Tutorial in Eclipse Java IDE [message #779606 is a reply to message #778609] Mon, 16 January 2012 01:28 Go to previous message
In the Import wizard, search for 'Plug-in' and you should get the option
you are looking for.
Deepak Azad
http://wiki.eclipse.org/JDT/FAQ
Previous Topic:Help needed for create jsp-servlet program..!!!
Next Topic:Context-sensitive help: Max usable size of a helpKey constant literal string?
Current Time: Sat Jul 26 02:22:44 EDT 2025
Powered by FUDForum. Page generated in 0.04895 seconds
