Home » Eclipse Projects » Virgo » faild to build org.eclipse.virgo.kernel.userregion
faild to build org.eclipse.virgo.kernel.userregion [message #766161] Thu, 15 December 2011 04:56 Go to next message
hi,
i got the virgo Core runtime Source code from
git.eclipse.org/gitroot/virgo/org.eclipse.virgo.kernel.git
and i try to build it,
the build start good but it failed with this line:
org.eclipse.virgo.util#org.eclipse.virgo.util.osgi.manifest;3.0.2.RELEASE: not found
it try to download it from :
build.eclipse.org/rt/virgo/ivy/bundles//
but there is no in RELEASE version (only in snapshot),
i search who try to work with this version(in ivy dependency) and didn't find.
any help will appraised.
Re: faild to build org.eclipse.virgo.kernel.userregion [message #766170 is a reply to message #766161] Thu, 15 December 2011 05:08 Go to previous messageGo to next message
Do you configure the jar for Manifest.Mf file? If your project life cycle is Maven? please try this way but not yet sure?
<dependency>
<groupId>org.eclipse.virgo.util.osgi</groupId>
<artifactId>virgo</artifactId>
<version>${virgo.version}</version>
<type>jar</type>
<scope>test</scope>
</dependency>
Re: faild to build org.eclipse.virgo.kernel.userregion [message #766191 is a reply to message #766170] Thu, 15 December 2011 05:45 Go to previous messageGo to next message
I've had a look round the code and something odd is going on, certainly looks like a bug on our side.
Could you raise a bug for it and it will get looked at. https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Virgo
Apologies for the problems building, are you specifically trying to build 3.0.2.RELEASE, could you use the master branch?
Thanks, Chris.
Re: faild to build org.eclipse.virgo.kernel.userregion [message #766234 is a reply to message #766191] Thu, 15 December 2011 07:23 Go to previous messageGo to next message
thank you for your help
i will raise a bug like you ask,
and i realize now i need virgo 3.0.1.RELEASE and i was working on virgo 3.0.2.RELEASE
Re: faild to build org.eclipse.virgo.kernel.userregion [message #766331 is a reply to message #766161] Thu, 15 December 2011 10:09 Go to previous messageGo to next message
where i can find virgo 3.0.1 source code (git tree)?
Re: faild to build org.eclipse.virgo.kernel.userregion [message #766644 is a reply to message #766331] Fri, 16 December 2011 02:20 Go to previous message
Here are the Virgo repos
http://git.eclipse.org/c/virgo
choose the one that you need and then in the section with the tags you can download an archive with the sources for every particular tag.
Violeta
Previous Topic:Virgo IDE error: No value found for placeholder 'project.name'
Next Topic:NamespaceHandler
Current Time: Sun Jun 15 23:37:09 EDT 2025
Powered by FUDForum. Page generated in 0.04108 seconds
