Home » Eclipse Projects » Virgo » Virgo 3.0.2 Released
Virgo 3.0.2 Released [message #759284] Mon, 28 November 2011 04:31 Go to next message
Virgo Maya (3.0.2) release is available.
The release includes bug fixes for Equinox Registry, Virgo's Medic configuration and Java Util Logging support.
http://www.eclipse.org/virgo/download/
[Updated on: Mon, 28 November 2011 04:31] by Moderator
Re: Virgo 3.0.2 Released [message #760584 is a reply to message #759284] Sat, 03 December 2011 02:23 Go to previous messageGo to next message
Hi friend,
I have currently using virgo server 2.1.0 it's working fine with my war file and application then i move to virgo 3.0.2 using this server and deployed my war file it's came to bundle state failed error please help me.
My workarounted for this version i am try to change the parameter for org.eclipse.virgo.web.properties --> replaced WABHeaders=strict to WABHeaders=defaulted but i did not solve the problem if you any idea? please let me know. ASAP.....
Re: Virgo 3.0.2 Released [message #761009 is a reply to message #760584] Mon, 05 December 2011 14:16 Go to previous messageGo to next message
Do you redeploy your application after changing that property?
Re: Virgo 3.0.2 Released [message #761400 is a reply to message #761009] Tue, 06 December 2011 07:33 Go to previous messageGo to next message
My issue was solved thanks and thanks lot you valuable time spending for me, I will keep it your friendship and knowledge sharing.
Re: Virgo 3.0.2 Released [message #825053 is a reply to message #761400] Tue, 20 March 2012 08:02 Go to previous messageGo to next message
Kindly I want another one help, at the very first i am developing my application 2.0.1 and 2.1.1 it's working fine my application and war file, after i move to another level means next version 3.0.0, 3.0.1 and 3.0.2 virgo server deployed my application was bundle failed exception came to me, so i had follow the your instruction for changing that property for org.eclipse.virgo.web.properties --> replaced WABHeaders=strict to WABHeaders=defaulted it's application war file working fine and fixed issue, but i want another requirement for my project manager ask to me to fixing this issue without changed the property file parameter, So please if there any idea or way let me know...
I expecting your valuable instruction....
karthik
[Updated on: Tue, 20 March 2012 08:02] by Moderator
Re: Virgo 3.0.2 Released [message #825434 is a reply to message #825053] Tue, 20 March 2012 16:58 Go to previous message
One option is to deploy WAB instead of a traditional web application.
Another option: we may downport to 3.0.x the fix for https://bugs.eclipse.org/bugs/show_bug.cgi?id=354730 that I'm preparing.
Previous Topic:How to debug with Virgo
Next Topic:Servlet ClassNotFound exception
Current Time: Thu Jun 19 01:57:18 EDT 2025
Powered by FUDForum. Page generated in 0.06229 seconds
