| Auto-positioning nodes in the root edit part [message #75739] |
Wed, 16 April 2003 00:13  |
Originally posted by: m.spork.NOSPAMtpg.com.au
How can I automatically position elements in the root edit part
depending on how big the canvas is?
For example - I want to position a child node about midway on the
vertical (left-aligned). Where do I put the code so that the child
node is repositioned correctly whenever the canvas is resized - and
how do I get the new size of the canvas?
Murray
| Re: Auto-positioning nodes in the root edit part [message #75909 is a reply to message #75760] |
Wed, 16 April 2003 23:58  |
On Wed, 16 Apr 2003 10:43:54 -0400, "Randy Hudson" <none@us.ibm.com>
wrote:
>The Viewport figure will position its "contents" figure such that it fills
>the entire available space (i.e., the canvas minus the scrollbars if they
>are visible). Layout is done top-down, so once your contents figure has
>been placed, it will then layout, and it can place its child in its center
>location.
Hi Randy,
I'm still having some difficulty with this.
I'm not sure where to put the code to do the laying out of the child
elements. I tried putting it in the refreshVisuals() method of my
contents edit part - this method is called sometime shortly after the
contents editpart is added to the root - but it appears that at the
time it is called the Viewport figure has not been sized to the full
canvas (it shows a height of 32 and width of 64).
Can you advise as to what method in what class I should override to
put this laying out code in?
Murray
>"Murray Spork" <m.spork@NOSPAMtpg.com.au> wrote in message
>news:oqlp9v8of3ikd8sso93c3tf4k9u4j379jd@4ax.com...
>> Hi,
>> Thanks
>> Murray
FUDForum. Page generated in 0.06093 seconds
